No. That's the variable FLOW pump. I have the variable SPEED (think RPMs) pump.
Does one have an advantage over the other? People seem to think the FLOW pump is better, not sure.
I don't know the exact flow spec for the SWG off hand. Perhaps others do but it's usually pretty low.
Also, the IntelliChlor's chlorine output is INDEPENDENT of flow rate. An IC60 generates 2lbs of chlorine gas per day FULL STOP. It doesn't matter if your flowing water just above the cutoff flow rate or at the highest speed possible.
Got it. So without the Easytouch, is the IC-60/powercell on a manual timer while my IF would be on its own but they are BOTH on the same power supply?
WAIT A MINUTE: If the IC-60 generates a fixed rate of chlorine gas, what does the percentage on it adjust?
