Results 1 to 11 of 11
Thread: No chlorine
    Apr 2016
    Merrick/NY
    21
    No chlorine
    Opened the pool about a month ago but went away for a couple of weeks.
    I purchased the test kit. Just ran the two chlorine tests...the one in the blue box (Water was colorless) and the one in the "chlorine only" cylinder, did not get a pink color.
    So I'm assuming I do not have any chlorine in the pool, same goes for free chlorine.
    My SWG is at 30%.
    Any suggestions/help much appreciated!
    15K gallons, IG free form, concrete construction, vinyl liner, Jandy DE filter, SWG, Heat Pump, water restrictions. Located in northeast
    Donldson's Avatar
    NW Ohio
    2,898
    Re: No chlorine
    First, just want to cover your test kit details. The chlorine test in the blue box is called an OTO test, it measures total chlorine which is FC+CC. If it was colorless then you have neither. The other one is an FAS-DPD test, it measures FC, then you add the 5 drops of R-0003 and if it turns pink you have CC and can measure that. Just wanted to make sure you have the right understanding of the tests.
    Ok, so you have no chlorine, which is a problem. Have you measured your CYA level? If it is low then you might be losing FC to the sun. Either way you will want to get some chlorine in there right away so adding liquid chlorine to supplement your SWG will get your level up immediately.
    How does your water look?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2016
    Merrick/NY
    21
    Re: No chlorine
    Thanks for the quick reply!
    Yes those are the tests.
    Water looks clear. Will check CYA level tomorrow.
    So just add generic store brand liquid bleach? In skimmer or throughout pool? How much?
    Thanks again!
    triptyx's Avatar
    Apr 2016
    1,438
    Re: No chlorine
    Add it near a return, and then brush it around a bit with your brush. Store brand liquid bleach is great as long as it's unscented and is not "splashless".
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: No chlorine
    Apr 2016
    Merrick/NY
    21
    Re: No chlorine
    Ok just took my CYA level and that's very low also, I was able to see the black dot when cylinder was completely full.
    I have my bleach ready to go for the chlorine, should I deal with the CYA level
    1st?
    Any suggestions and help much appreciated!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: No chlorine
    You can do them at the same time. Add bleach, then get sock full of CYA hanging in front of a return.
    edit: While you are waiting for the sock to dissolve you could fill out your signature
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    DFW, TX
    24,497
    Re: No chlorine
    Here is what we need in your sig to better help you with your pool, Pool School - Read This Before You Post
    Aug 2010
    Dallas, TX
    4,052
    Re: No chlorine
    To clarify, don't put stuff in your skimmer.
    Apr 2016
    Merrick/NY
    21
    Re: No chlorine
    Ok, bleach has been added, as well as the conditioner. When should I retest again?
    And Robbie thank you for clarifying about the conditioner not going in the skimmer,
    I know I read to do that somewhere and that's where I originally put it.
    Also not sure why my signature is not showing up, it's filled out. Is there a reason it's not visible to people??
    Thanks everyone, this really is a great site! Very helpful and informAtive
    DFW, TX
    24,497
    Re: No chlorine
    Need to check the Show Sig box below the text box. Once checked it will stay checked.
    Here is a sheet showing how to add chemicals, Pool School - Recommended Pool Chemicals
    Test FC after 15 minutes. Test CYA 24 hours after it is dissolved from the sock.
