Thread: How would you aim these returns?
    May 2016
    Albany
    12
    Top and right are just straight shooters. Bottom is eyeball currently facing right but not upwards or down. Pool is about 21000 Gallons I think. Sorry for my fun MS PAINT. I can replace all with eyeballs or whatever else. First year with pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: How would you aim these returns?
    I would aim the lower one to the right and see how it goes. I would recommend a counterclockwise rotation anyway as the first thing to try. I think there is a chance that the upper left return could now debris past the skimmer if you went clockwise.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    What I personally would start with, just to see how it goes.... Clockwise, from the skimmer. 9:00, 10:00, 3:00. 2:00, 8:00.
    Save some empty plastic water or coke bottles with the caps or buy some ping pong balls and toss them in the pool this weekend and sit and watch with a beer. As long as nothing ends up stuck in a corner, it should skim.
