Thread: Mutagenic pool water due to disinfectant byproducts
    Apr 2013
    Central Massachusetts
    174
    Interesting read over on phys.org referencing a study on pool/spa water and how disinfectant byproducts build up over time:
    Hot tubs and swimming pools are not as clean as you may think
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Mutagenic pool water due to disinfectant byproducts
    Interesting read!
    Maybe they should have tested more TFP user's pools!
    It should be noted that none of the pools sampled were outdoor residential pools. One pool was an outdoor public pool that also used ozone. It would be interesting to do this same study on pools maintained by TFP methods (ie- allow usage or higher levels of CYA and higher FC levels). Outdoor pools have the advantage of sunlight to further break down DBPs. Private pools also do not see nearly the bather load, which is emphasized as a problem for the creation and build up of DBPs. Also makes sense why the spas had such higher levels. They have high bather loads by volume and elevated temps creating more DBPs more quickly and likely limited exposure to sunlight.
    Isolated Spa - 345 Gallons
    Apr 2013
    174
    Very good points JV!
    My Build thread
