Results 1 to 8 of 8
Thread: Intex Deluxe Wall Mounted Skimmer for Coleman pool
    DobermanOwner's Avatar
    Mar 2016
    Topeka Kansas
    36
    I have a 16' Coleman ultra frame pool and today I installed the Intex Deluxe Wall Mounted Skimmer to it. Thankfully, all parts work for the Coleman pool, but unfortunately it doesn't appear to be working. My guess is because my pool has two inputs and one output. The skimmer is only attached to one of the inputs, so it doesn't have a whole lot of suction power. I am considering buying a second skimmer (only $12.99 at Academy Sports) and using the parts to modify the plumbing a bit on the one I have installed. I need to find a T connector to connect to the bottom of the basket so that I can use two hoses instead of just one. Has anyone done this? I have watched videos of the skimmer in action, and you can see the water flowing over the blue floating ring part, pulling debris inside. Mine doesn't do that until I gently push it just below the surface of the water and drop a blade of grass in....
    16' x 48" (5,145 gallons) Coleman Power Steel round frame above ground pool
    1500-2500 gallon Coleman model# 90401E cartridge filter (stock)
    TF-100 test kit
    Set up and Filled May 2018 (3rd summer with it)
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: Intex Deluxe Wall Mounted Skimmer for Coleman pool
    Mine works good. I have dual suction inlets but I changed my pump to a Hayward. You could always block off the other inlet hole and just run off of the inlet hole that you have your skimmer connected to ...
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    May 2017
    Denver CO
    2
    How did either of you connect the Intex skimmer to the Coleman inlet hole?
    May 2017
    Detroit, mi
    7
    Quote Originally Posted by Poolforfun View Post
    I just did this yesterday. If you pull out one of the inlet plugs, you'll see two small screws on either side. Remove those screws and you can unscrew the dome shaped cover. Then you can screw the blue hose attachment to the inlet plug and put it back into the inlet.
    Angie
    7k gal, AG, vinyl, 1500 gal cartridge pump, install May 2017
    Jun 2017
    Sparks, NV
    1
    Sorry. Brand new and can't find "post new thread" link. I have the wall mounted skimmer and the blue cover just floats on "top" of the water so no water flows across or into
    it. I duct taped a rock to it so it sinks enough to let water into the skimmer. Any ideas on a better way to let water flow "into" the skimmer? Thank you.
    sidebar: I, too, have the two lower hoses, so almost no suction. What purpose does two lower hoses serve, anyway? If it just means low suction, I will plug one of the hoses or eliminate it completely.
    Intex metal frame above ground pool 16'x48"
    Intex Deluxe wall mounted pool skimmer
    May 2012
    Caledonia, MS
    123
    Quote Originally Posted by Jackohlope View Post
    The reason for dual suction is safety and now required by law in the US. The complaint was that a single suction can be too strong for a child to pull away from if their hair were to get caught in the suction.
    As for the skimmer, no need to weigh it down. You want it floating at water level. If you lack suction you can block the 2nd suction or put something in the fitting to reduce the flow. I tried that and didn't like it so I changed both to 1.5" and plugged one and the other is connected to my skimmer.
    Intex 22x52 - New 2017
    3/4 HP Doheny Pump
    16" Hayward filter
    Intex SWG
    Jun 2017
    North haven
    5
    Hold on am i supposed to be using those plastic strainers for the outlets for those 2 circulation holes ??!! For outlet into the pool ??
    And i can plug up one hole ??!
    Jun 2017
    North haven
    5
    Thats what i did . works fantastic
