Results 1 to 7 of 7
Thread: Need help putting in my pool deck umbrellas
    Sep 2015
    Phoenix, az
    15
    Recently we had strong winds and a storm. My pool umbrellas fell out of the pool deck hole. I am not sure how to put them back in?
    I've attached pictures of the anchors & pool umbrella. If anyone could help with me getting the umbrellas back into the pool deck I would greatly appreciate it.
    Thanks in advanced.
    Re: Need help putting in my pool deck umbrellas
    Quote Originally Posted by GoodMorning View Post
    Thanks in advanced.
    Were the spikes used to adjust teh height of the umbrella in the hole or simply to keep it stabilized (keep it from rattling around as the wind pushed on the umbrella)? Looks like a jury-rigged setup where the spikes probably sandwiched the pole (with their tabs facing outward, of course).
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Thats exactly what I was thinking too, Geebot.
    Yip
    Sep 2015
    Phoenix, az
    15
    Quote Originally Posted by Geebot View Post
    I'm not sure?
    What do you suggest? Do I need to buy anchors?
    Houston, TX
    1,105
    No, you do not need new anchors.
    1. Put umbrella in the hole and hold the middle of it [note, make sure the spikes are next to you].
    2. Straighten the Umbrella and push in one spike w the curved sides inward: aka, the rounded/elliptical side hugging the shaft of the umbrella [inward]
    3. lastly, insert the other spike the same way, but 180 degrees [on the other side] directly opposite of the first spike
    PS - when done w umbrella, close it up and apply a tie-strap
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jan 2012
    7,367
    can't you just re-use those spikes? Lift umbrella up and place in hole. Use spikes to wedge against umbrella pole so that it doesn't move about.
    Sep 2015
    Phoenix, az
    15
    Quote Originally Posted by tstex View Post
    Thanks. I will try what you just mentioned.
