Results 1 to 9 of 9
Thread: I did something foolish
    Jun 2015
    Okemos MI
    63
    So! I'm back. First year closing the pool last year, first time opening this year. Of course I opened to a green pool. I was going to open 2 weeks ago, but last week was cold (with snow!).
    I had to buy a plumbing part from the local pool store, and while I was there figured I would pick up some cya. The dude sold me "pro team up shield" and said it was not cya. So what is it, and does it work the same as cya (I.e. Not showing up in tests for a week)?
    Debating if I should start a slam now, given that we probably don't have any cya in there now. Lots of rain water over the winter.
    Next time I will be more prepared and just buy the cya ahead of time.
    Last edited by Bama Rambler; 05-18-2016 at 12:45 PM. Reason: Removed language filter circumvent attempt.
    29,000?gal in-ground concrete rectangular
    Pump: Hayward SP2610x15 Filter: Hayward S-244T (Sand) Chlorinator: Hayward CL-200
    2 skimmers; plugged main drain (reason unknown)
    New pool owner! Hooray! /sarcasm
    22,553
    Re: I did something foolish
    I assume you mean "Proteam UV Shield". If that's the case, it's 100% cyanuric acid (CYA). You can use Pool Math to figure out how much CYA you have by how much you added.
    P.S. It should show up on the test in about 2 days after it's fully dissolved.
    How did you add it?
    Donldson's Avatar
    NW Ohio
    2,926
    MSDS said it is CYA. Don't trust pool store employees.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Sep 2015
    Rome, NY
    363
    I would post your readings and go from there.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Jun 2015
    Okemos MI
    63
    Quote Originally Posted by Bama Rambler View Post
    Yes. THANKS AUTOCORRECT.
    I added the whole thing to a thick sock which I then put in one of my skimmers. I'm certain it's not nearly enough; the bottle said to use 1 lb/3000 gallons and I just got the small one.
    It is a beautiful, warm, nearly cloudless day here so I'll probably wait until tonight to add the bleach. I hate to waste it!
    22,553
    How many lbs was the container? Looks like it comes in 1½lb & 8lb containers. Probably the 1½lb, huh?
    Jun 2015
    Okemos MI
    63
    Yup. I didn't look at the label before I bought it. Really it's just as well. It was, of course, way more expensive than what I *should* have paid.
    Jun 2015
    Okemos MI
    63
    TC: 8.5 / FC: 8.5
    TA: 80
    CH: 200
    PH: 8.5+++++++ :O
    CYA: 20ish
    Comparison shots from yesterday and just now (post chemical dump)
    Jun 2015
    Okemos MI
    63
    Not as blue as the picture makes it look. Just added our last bag of shock and a quart of clarifier.
    TC: 6.5 / FC: 6.5
    Ph: 8.5++++++
