Thread: Drain help
    Sep 2015
    Los Angeles
    31
    Drain help
    Hi!
    My inground spa constantly gets Jacaranda twigs in it which then get stuck in the valves. It's a real pain. I have standard Heyward drains on now. My pool guy recommended putting panty hose over the drain which seems like it would work, but I'd like a more permanent solution. Any drain recommendations? Are there speciality drains?
    Any help is much appreciated.
    Thanks!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
