Results 1 to 14 of 14
Thread: Pebble plaster trouble in WEEK OLD POOL
    samwestx's Avatar
    May 2016
    Weslaco, Texas (DEEP SOUTH TEXAS)
    99
    OK......seen a couple of brownish/light rusty spots close to each other in the same area AND have about a nickel/quarter size (width) "hole" where the plaster "disappeared" (maybe an 1/8-1/4 inch in depth)..........what should i expect them to say AND do to repair......thanks in advance!
    they are coming in today to inspect
    15000 gallon pool (15x30 + 7x7 sitting area), IG-Blue Pebble, Sand Filter-Hayward Pro Series, Pump-Hayward Tristar VS pump, Water Test Kit-TF 100, NEW POOL-COMPLETED ON 5/7/16, City Water w/no restriction, Dolphin M400
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pebble plaster trouble in WEEK OLD POOL
    Pebbletec can patch that area with matching material.
    This page should help diagnose/understand the stain issue, Diagnosing Pool Plaster Problems
    samwestx's Avatar
    May 2016
    99
    ok......more brown/rusty SPOTS, NOT stains......what is going on?
    DFW, TX
    24,497
    Rarely there is a pebble in the mix that is not a not a pebble and can make a rust spot. We had one last year. PB dug it out and put some epoxy in the hole.
    samwestx's Avatar
    May 2016
    99
    Hole has been repaired.....spots are now my CONCERN
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Share a picture or two, it will help people better understand what you are dealing with....
    samwestx's Avatar
    May 2016
    99
    those (may be hard to see in pic) showed up first......within a couple of days......
    these are most recent......spoke to a few locals......they speculate PB may be using CHEAP tablets for free month's cleaning....wdyt?
    samwestx's Avatar
    May 2016
    99
    ok......REALLY weird....the SPOTS disappeared, but reappeared elsewhere.......the people at the forbidden place on this site (Leslie's-I ONLY went there because I HAD to get a vacuum hose) say that my PB shouldn't be using tablets on a new pool just yet....said the spots were because of stressing plaster to early with chlorine....ANY IDEAS?
    *recent spots
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Tablets are far less harsh on new plaster than liquid chlorine would be since there really isn't an accurate way to measure very low levels of liquid chlorine (<1) additions. What they are telling you is simply not correct.
    Tablets release chlorine and CYA very slowly. Any chlorine added is also somewhat buffered by the CYA that is also slowly being added. Had liquid chlorine been added to 2-3 ppm, that would be far more harsh since there isn't an adequate amount of CYA to buffer the strength. With that said, 3ppm of chlorine will not cause rust stains to magically appear, disappear and reappear elsewhere. You have something else going on.
    What happens when you brush the spots?
    Crush a vitamin C tablet and rub it on a stain, what happens?
    What are the current test results? Are you responsible for maintaining the pool?
    Did you have any rust spots on the gunite prior to plaster?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Reddogdan's Avatar
    Sep 2013
    Mansfield, Texas
    242
    Also, when they filled the pool, did they just throw water hoses in or float the metal ends of the hoses?
    14.3k, 3 1/2-5 1/2, IG, Pebble Wet Edge Northshore Tahoe, Jandy 4 cartridge, Jandy 2hp variable, Pentair 320 inline chlorinator fed by a Stenner, Polaris 280, K-2006 test kit, Built 9/13
    Fill water: TA=90, PH=70, CH=90
    samwestx's Avatar
    May 2016
    99
    They laid the hose on the floor as it filled
    samwestx's Avatar
    May 2016
    99
    Surely, it's how they've done it.....would've learned it was a problem in so many builds?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Quote Originally Posted by Reddogdan View Post
    Most hose fittings are brass or some sort of deivative that will not rust is the short time the hose was actually in the pool. Additionally, pebble finishes are allowed to cure for 24 hours and then acid washed before filling so the surface is hard enough that a hose fitting will not cause damage.
    -Brian-
    POOL BUILD
    samwestx's Avatar
    May 2016
    99
    Just found out that the most recent stains are coming from something flying in the air.....deck had the same stains on it (stems from some reeeeeaaaaallllly small debris dark in color-from some form of landscape)....fell in pool as well and stained it....PB was there cleaning and took them off with powder chlorine....this ONE TIME.....should I practice this for the next time? Other solvent and/or solutions?
