Thread: Robot that will clean steps and ledges in fiberglass pool
    Aug 2015
    Middletown, NJ
    21
    Good Morning...I received a private label (Millenium XE) electric pool cleaner made by Aquabot as a promotional freebie with my pool when I installed it late last summer. I am not happy with it because it does not clean the 2' bench that runs the entire 40 foot length of my pool, the grab ledge that surrounds the entire perimeter or the steps. I would appreciate any recommendations for an electric pool cleaner that would clean the bench, stairs and ledge. I have a Leisure Pools Grande 40 model which is 16' x 40' rectangular fiberglass pool. Thank you for your time.
    20K gal, IG fiberglass installed 8/25/15, Pentair Intelliflo 3 HP variable speed pump, Pentair FNS Plus 48sf DE filter, Pentair Intellichlor IC-40 SWG, Aqua Comfort ACT-1250 Heat Pump, 3 S.R. Smith Pal Treo Lights with WPC1, S.R. Smith Turbo Twister Slide, S.R. Smith Swim N' Dunk Salt Friendly Challenge Basketball Game, Aquabot Millenium XE robotic cleaner, TF-100 Test Kit and K-1766 Salt Water Test
    38,275
    Re: Robot that will clean steps and ledges in fiberglass pool
    I am not aware of any electric robot that successfully navigates on ledges and stairs.
    Jan 2012
    'burbs of Augusta, Georgia
    7,336
    I have the same problem- a ledge runs the length of my fiberglass pool. I've never found anything out there that will climb the ledge and move on. Darn it.
    Aug 2015
    Middletown, NJ
    21
    Thanks to you both.
    @YippeeSkippy: What kind of manual vacuum head do you use? The triangle one I got from the pool builder didn't seem to work well so we got a long weighted rectangular one from Home Depot and that didn't seem any better. Perhaps we are doing something wrong? I have a 3HP pump so I did not expect to have such a hard time getting the pool clean. Thanks again.
    Jan 2012
    7,336
    I don't use those big tubed vacuum heads anymore. We only need to use the small PoolBlaster Max vacuum since we have an auto cover and don't get much debris in the pool.
    I just wanted a robot that would climb walls to brush them so that we didn't have to do the brushing.
    Are you turning valves to increase the suction at the skimmer while you vacuum? That might help you.
