Thread: Can I close my bottom drain?
    Mar 2013
    CT
    348
    I have tons of pollen and little "tree seed helicopters" on the surface of my pool right now. The skimmer isn't able to keep up so I'm manually skimming a few times a day.
    Can I shut off my bottom drain completely for a few days to increase the power of my skimmer??
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Can I close my bottom drain?
    Yes, you can. I throttled mine back just to the point where I can detect a difference in the turbulence in the skimmer from no drain, so it's hardly any flow through the drain at all. Just enough to minimize temperature stratification.
    Mar 2013
    CT
    348
    That explains it.
    I have my bottom drain opened 100% at the moment. That will change as soon as I get home from work today.
    Thanks!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yep, I keep mine about 80% skimmer 20% drain. That way if the skimmer clogs up the pump can still get water from the drain. I only switch to 100% drain when I am brushing. I brush to the drain and don't have to vacuum. Handy! Especially since I don't have a vacuum!
