Results 1 to 10 of 10
Thread: Balancing with SWG
    May 2008
    Cary, NC
    26
    Balancing with SWG
    hi everyone,
    i tried to find the answer to my question on the stickies first, but i wasn't quite sure if i found the answer, so i figured i'd go to the source.
    i opened my pool last weekend but the pump was shot, so i had to order a new one. long story short, algae started to develop in my stagnant pool. once the pump came, i followed the advice on the board here and hit it hard before it ever got going. i am now algae free and my FC is holding overnight. here are my test results (done twice to ensure accuracy)
    FC 4.5
    CC ~ 0.5
    TC 5.0
    TA 90
    CYA n/a there was no CYA when i opened, i added some after i got the algae under control. too early to test
    CH 140
    PH 7.2
    my 2 questions are: 1)i know calcium hardness is not that big of a deal with a vinyl liner, but i just wanted to make sure that # is ok... and 2)i know the ph is a bit on the low end, but with a swg will that drift up on its own? or should i raise it myself?
    thank you to everyone on this board for all your help!
    25K gallon IG vinyl liner, Intellichlor IC40 SWG, Sand Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Balancing with SWG
    Your numbers are fine, no worries on the CH and the PH is okay, it may rise on it's own.
    Keep your FC up with liquid chlorine and when your CYA is in range you can use the SWG. However, you don't give a salt reading?
    Looks like you have a handle on things.
    May 2008
    Cary, NC
    26
    i actually just started up the swg now that i have my FC stable and holding. my salt reading was 3400 ppm but i am ordering some new salt strips since the ones i have are old and right at the exp date.
    thanks for your help!
    11,969
    You may have some problems if your CYA isn't at the right level. Hopefully it will be alright. What was your target?
    May 2008
    Cary, NC
    26
    right around there. the range is something like 3200-3600. last summer i kept it right around 3400 with no problems.
    i will check the FC tonight and if it's on the low side, i'll turn off the SWG until i can get my CYA level up. thanks!
    Guest
    Get your CYA up to 80 ppm. If you find that you have to add acid frequently to keep the pH down then drop your TA to about 70 and consider adding borates.
    water-balance-tips-for-a-swg-t3663.html
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    May 2008
    Cary, NC
    26
    thanks waterbear! i'm pretty sure i added enough to get the CYA up to 80, but i will test soon. how long does it usually take for the powder to dissolve?
    also, have you heard of a ph reducing product designed specifically for swg? i'll have to see what the exact ingredients are, but i wanted to ask the board before buying it. i've read on here that muriatic acid can be a little risky for swgs?
    Guest
    Quote Originally Posted by goodnterribles
    usually about a week
    Nope, muriatic acid is the best thing to use for SWGs. it's dry acid and sulfuric acid that can sometimes be a problem. Muriatic acid is also what EVERY SWG manufacturer that I have ever seen or sold recommends for cleaning the cell!
    The 'pH reducing product designed specifically for swg' is really designed to play to a customer's ignorance and lighten their wallet! Give me a brand and a name and I will check into it but I bet it's just dry acid if it's a granular product and muriatic if it's liquid.
    May 2008
    Cary, NC
    26
    thanks waterbear! i obviously was confused. the next time i'm at the store i will look to see what it is.
    Jun 2007
    NC
    255
    Muratic is inexpensive too. It's 2 gal for $10 at Home Depot!
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
