Thread: Anyone Use This Brand Chlorine?
    Jun 2014
    Chandler, Arizona
    88
    Home Depot just started selling 10% sodium chloride chlorine for $6.86 for 2 gallons; brand is "HDX." It was a much better deal than the price I was paying for the HASA brand I was buying at a local mom and pop store. What I've noticed is that it may not be of equal quality. It seems to burn off relatively quickly. I double checked the julian number and here is what it shows: 16 10506:27 C. Is this a good number? I purchase 8 boxes 2 weeks ago.
    Also, it is almost odorless. Is this normal?
    28k gallon in-ground pebbletec pool w/waterfall and grotto feature
    Triton II sand filter
    "The Pool Cleaner" 4-wheel vacuum
    1.5hp main pump; 1.5hp water feature pump
    Taylor K2006 test kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Anyone Use This Brand Chlorine?
    Hey there, that chlorine was made on Apr 15 this year, I have not used that type..
    have you checked walmart? They have had 10% for 2.50 a gallon in the pool isle...
    Jun 2014
    Chandler, Arizona
    88
    In general, how does one read a Julian number?
    Holy cow, that's cheap! I'll give Wal-Mart a look this weekend. Thank you!
    Any feedback on if I should be concerned with the chlorine being odorless?
    Feb 2015
    Chandler AZ
    938
    You might also wish to check chlorine at A&M Corson's on NE corner of McQueen and Warner (also Alma School and Elliot). 12.5% for $3.75/gallon when you get 4 gallons in refillable jugs - $14.99 for 4 gallons.
    Also, in reference to your pH issue in your other thread.... 4 gallons of 31.45% for $18.99.
    In both cases, they charge a $6.00 refundable deposit for the 4 jugs and carry case. The chlorine has always been fresh.
    Of course, the 10% for $2.50/gallon at Walmart is a little better value per effective ounce of chlorine.
    Date code decode for Walmart "Chlorinating Liquid".... 16120 = 120th day of 2016 (around end of April 2016). Make sure it starts with a 16 - someone yesterday mentioned they saw one somewhere that started with 15. You want the freshest possible as it degrades over time.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Feb 2015
    Chandler AZ
    938
    It's also been reported that HD tends to leave theirs outside in the heat - not good.
    Gene
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    There is no 'easy' way to test the chlorine for strength, "in bottle" I've read that it should be yellowish, should smell pretty strongly, and might have a certain feel on your finger. I would NOT recommend the finger test. If you have some way to accurately measure liquids, you could try to dilute it down to something that can be measured with the FAS/DPD kit.
    Usually, I would say, just add what pool math says you need and if it doesn't raise FC like it should, it's probably not full strength anymore. That is assuming that your pool is otherwise in good shape, and that you aren't fighting an algae battle.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
