Yuck, things aren't improving.
Have you had a pH test yet where you were under 8.0? Do you ever test shortly (30 minutes or so) after adding the MA? Overnight or all day could be long enough for the pH to rise back up. If you end up figuring out your dosing you could get this where you can add in the AM and the PM and really speed up the process.
It's a slow process - don't get discouraged or give up. Every time you knock down the pH and it rises back up, you knock a bit off the TA. It's too small to read with one or two cycles. But you'll find a difference in the TA in a week or two for sure - if you stay on top of it.
