Thread: Recovering baquacil user
    May 2016
    Beaumont
    1
    Red face Recovering baquacil user
    My wife thought she was alergic to chlorine , so being a new pool owner as well as a new husband , i thought baquacil was the solution. tence 4 years later , found out she was alergic to me, thats another story. so having pump issues , cavitating , bubbles , hard to prime, did a pump rebuild , still problems , started reading here , decided to drain pool and start fresh with BBB method. pool looks fantastic , plaster almost like . can't keep FC thru day , have no cya , at 0. started using tabs but probrably need to use stabilizer to raise cya faster. intrested in building a liquid chlorine injector that could last a week , im a shift worker , can't do a daily routine. any advice much appreciated. dont have funds to do SWG right now , but maybe in future
    Andyugh, 16,500 gal, IG , gunite , pentair whisperflow pump , pentair DE 60 filter , pentair 320 chlorinator , booster pump for polaris 390 , recovering baqucil addic , just drained pool , refilled , trying BBB , modified
    Casey's Avatar
    SW PA
    10,453
    Re: Recovering baquacil user
    Welcome! Do you have a TF100?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    welcome to TFP
    You can use a stenner or liqudator here Chemical Automation and The Liquidator
    I am not sure if you have seen these but maybe it would work for you... Chemical Automation and The Liquidator
    They both will cost about the same
