Thread: Pool Newbie - Gas Heater Saving Money Questions
    May 2016
    Barrie
    1
    Thanks for those that take the time to help a fellow pool newbie.
    First season with a 16x32 rectangle pool with 8ft deep end.
    Can anyone pass on any tips on heating? ie how to be efficient and save money. For example is it cheaper to completely turn off the heater when not in use or is it better to lower the temperature to reduce heat up time.
    I will take any and all tips and tricks.
    Thanks
    38,275
    Re: Pool Newbie - Gas Heater Saving Money Questions
    Welcome to TFP!!!
    Please add your location (City, AND State ... where is Barrie???) to your profile and pool details to your signature as described HERE as it will help us help you.
    The biggest tip is use a cover to maintain the heat in the water.
    The way to save the most money is to not run the heater
    How you maintain it really depends on how you use it. If you are only using it on the weekends, then likely cheaper to only heat it then or lower the temp during the week.
    Whatever you do, it is NOT going to be cheap.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Where are you located and is this a propane or natural gas unit? Natural gas is cheaper in many areas but when you do heat the pool and not using it, keep the pool covered. Invest in a solar blanket.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by nlemieux1978 View Post
    Thanks
    Not really sure what you mean by this^^^^^
    When the heater is on, it is on full. there is no low, med. high on a heater. It is a matter of BTU output and desired temperature. This along with the volume (weight) of the water will determine how long the heater stays on. If you are like me, and only use the pool on weekends, then, heating the pool all week long does not make sense. I turn my heater on on friday afternoon to warm it up for the weekend. I set the water temp to be in the mid 80's and how ever long it takes to get there is how long the heater runs. By doing it this way the heater may only run for 4-5 hours depending on the ambient air temps thru the week. If I tried to maintain the temp all week long the run time will be two the three times longer.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
