Results 1 to 7 of 7
Thread: Pump humming
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    475
    Pump humming
    Went to turn on the filter and the pump is just humming. It will hum for 30 seconds or so and then I have to reset the breakers (although they aren't thrown) to get it to hum again. Read on here that it is probably a bad capacitor. With power off, Took the filter basket out and couldn't reach the impeller. Took the back off and the shaft turns easily, but there is no slot for a flat head screw driver to turn it. I turned it by hand a few times and tried turning on the power but it still just hums. Took the capacitor out and will try to find a replacement tomorrow. I read somewhere that some motors have a run and a start capacitor. There only seems to be one cover on my motor and I only see this one capacitor in the end. It is 25MFD, 370 volts. Is that the start capacitor?
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    38,305
    Re: Pump humming
    Some motors have 2 capacitors, some have 1, and I think some have 0.
    If you only have 1 in the back of the motor (no big hump on the side of the motor), then that would be the start capacitor.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,812
    Re: Pump humming
    Not all capacitors are start capacitors, some are there to improve efficiency while running. Other motors have no capacitors at all. The hum and then no hum is likely caused by the thermal overload protection circuit in the motor. It will automatically reset by itself. It is there to protect the motor from catching on fire. Either way since the motor shaft spins free try replacing the capacitor that you see and it will probably solve what ales you.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    475
    Re: Pump humming
    Quote Originally Posted by CJadamec View Post
    I'm hoping so, thank you. I did notice that the shaft was quite hot after it humming for only a bit. I'd really like to get it going at least until I find a capacitor. If I turn it with pliers while someone else turns on the switch, it should start going? I read that it turns counter-clockwise on the pump end, so I'll need to turn it clockwise on the motor/capacitor end.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    475
    Re: Pump humming
    $10 for a capacitor and I'm back up and running!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,812
    Re: Pump humming
    back to the lounge chairs and cold beer
    Chuck-
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pump humming
    Life is good!
