Results 1 to 20 of 20
Thread: SaltWater Pool Opening help
    May 2016
    Edison, New Jersey
    18
    Hello,
    First thanks for reading my post. I am new to pool. I have salt water kidney shape pool. Last year we used a service to close the pool, this time I have put everything in place and started the pool. When i open the pool, it was dark green, searched online and found time to shock it.. i added 7 gl shock to pool and let it run for about 48 hours. The pool still looks cloudy but not that much green. I have electronic chlorine generator (Swimplus), the reading shows zero and no flow light stays on.. i tried to unplug and try setting didn't work.. my question is what do i need to do next? all levels are low at the moment. when do i add salt? PH? other things for the pool so it became crystal clear. and what could be wrong with reading box? please advice.
    regards,
    Matt.
    38,393
    Re: SaltWater Pool Opening help
    Welcome to TFP!!!
    How are you testing?
    To clear up the pool, you need to follow the ShockLevelAndMAINTAIN Process and that requires the FAS-DPD chlorine test that is part of the Recommended Test Kits.
    Forget about the SWG for now. Just turn it off until the pool is clear and balanced.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    May 2016
    Edison, New Jersey
    18
    I checked the levels with Test strip and all of them are shows low.
    38,393
    OK, pick up the pack of test strips, walk over to your garbage can and drop them in. Now invest in a real test kit
    Test strips are horrendous and just not going to be helpful. BTW, pool store testing has also proven to be very unreliable.
    May 2016
    Edison, New Jersey
    18
    buy which test kit? are you saying if I take water over to Leslie pool, their testing is also no good?
    when should i add salt to pool, after pool is clear or now?
    38,393
    Yes, I am saying that I would not trust any numbers coming out of Leslies.
    The link I provided in the first post lists the recommended test kits. If you just want a suggestion: get the TF-100 with the XL option from tftestkits.net
    Forget about the SWG and the salt ... you have more important things to worry about like getting the water clear first
    For all we know right now, there might be a reason that you have to replace water, so why add salt you might pump out?
    May 2016
    Edison, New Jersey
    18
    Here are numbers after opening pool for three days:
    Salt - 2600
    FAC 0
    ph 7.2
    TA 60
    cya 0
    TC 0
    CH 120
    water temp is around 60.
    Pool Pictures:
    Aug 2010
    Dallas, TX
    4,052
    You have not finished your SLAM. Are you following those procedures, or are you following pool store procedures? The two will not intermix.
    May 2016
    Edison, New Jersey
    18
    this is how the pool look right now:
    May 2016
    Edison, New Jersey
    18
    I am following SLAM process. I have added 7 gl of liquid shocks and the filter been running for 48+
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,081
    How often do you test and add chlorine?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Edison, New Jersey
    18
    every 6 hours and 1 gallon of chlorine if needed.
    May 2016
    Edison, New Jersey
    18
    am I doing something wrong or not following proper procedure?
    Aug 2010
    Dallas, TX
    4,052
    If FC is falling to zero, you are not adding enough chlorine to the pool, or you are not testing and re-adding often enough.
    48 hours is not long at all. SLAM can take several days and occasionally a couple weeks or more.
    How do you determine how much chlorine to add after each test?
    May 2016
    Edison, New Jersey
    18
    Ok. After 2 and half week of running filter, pool looks like this.. not crystal clear but still little cloudy..
    Today's results:
    FC - 2
    CC - 2
    pH - 7.6
    TA - 80
    CH - 170
    CYA - 10
    May 2016
    Edison, New Jersey
    18
    pics attached.
    38,393
    Does not look like you are following the SLAM process if your FC is that low.
    May 2016
    Edison, New Jersey
    18
    I am...was out for a week didn't add anything last week. The FC was 3 last checked so no needed..Today I added Stabilizer and Hardness today, will let it run for 24...please advise if I am doing wrong.
    Apr 2016
    Kankakee Il
    39
    follow the advice given on the forum word for word even if it requires a slight inconvenience such as having to babysit the pool. Look at their pools, unbelievabley clear and sparkly, these people know what they are doing and can prove it. Read the guides and good luck with your endeavors.
  20. Back To Top    #20
    38,393
    Please fill out your signature. The pool looks like vinyl and there was no need to increase the CH.
    Just lower the pH and focus on maintain the shock level FC for your targeted CYA.
