Thread: high alkalinity. low ph...help
    May 2016
    Maple Grove, MN
    1
    I have been to numerous pool stores and everyone is telling me something different. My TA was 230 and ph was 7.6. They told me to add 3 gallons of muriatic acid 1/2 gallon at a time in one spot in the deep end of the pool with pump running. Went and got the water tested a week later and TA went to 248 and ph 7.1 My CYA is 39, total chlorine is 9.9. What can I do to get these numbers where they are supposed to be. The pool is crystal clear and have not turned the heater on yet in MN so the water is 60 degrees. Pump is running continuously. Any help would be greatly appreciated! I can't go back to the pool store and have someone give me another wrong answer!
    20,000 gallon salt water
    in ground vinyl
    pentair cartridge filter
    intellichlor chlorinator
    38,537
    Re: high alkalinity. low ph...help
    Welcome to TFP!!!
    This is why we do not trust pool store testing. Invest in one of the Recommended Test Kits and find out your REAL levels.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome tO TFP!
    Good idea! I use the TF100 from TFTestkits.net. Get one and never look back!
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by pooldv View Post
    Welcome tO TFP!
    After you get the kit and a week or so later, you will find it pretty easy. When I first started up my new pool, I was trying to get to the pool store every day to ensure all was right. I actually already had the TFT kit but wanted the print outs for warranty purposes. The fun of going to the store daily wore off really fast and I am just recording the numbers myself in the spreadsheet. Within the few weeks I have been doing this, I already started to get a feel for what is needed. Right now with a new pool, I need 10-14oz of Acid and Chlorine a day to maintain once I got my CYA to 30.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP, we can get you going
