Results 1 to 7 of 7
Thread: Intex 14' sand filter conversion *HELP*
    May 2016
    Lubbock
    7
    Hello all, new here so forgive me if this isn't in the correct spot. I've had an 18' Intex agp for the last eight years. The kids are moving out of the house so I am replacing it with a 14' Intex. I've got the ground prepped and am ready to start the setup when I notice the pump inlets and outlets on the liner are much smaller than those from the previous pool. I've seen where they sell adapters for this but I am no fan of that solution. Seems it would restrict water flow and possibly make the pump work harder. Any who - does anyone know of a solution to this problem before I take the pool back and go to 18' again? Thank you
    38,281
    Re: Intex 14' sand filter conversion *HELP*
    The smaller ports will only slightly impact the flow rate and should not cause the pump any problem.
    May 2016
    Lubbock
    7
    It is an 14' x 42" Intex Ultra Frame.
    Intex 14' x 42"
    Intex 2650 GPH sand filter
    May 2016
    Lubbock
    7
    Just noticed the liner has two inflow ports so I should be good there, but the outflow port is Way smaller than the original I was using. Seems the pump would just blow the cover right off. 20160517_155033.jpg20160517_155119.jpg
    Intex 14' x 42"
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    All sizes of new intex pools come with the two smaller outlets replacing the old style, single larger outlet. Intex intends for both smaller outlets to be combined via the "T" valve. Many of us have cut out the smaller outlets and replaced them with standard 1.5" outlet fittings.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    May 2016
    Lubbock
    7
    Philc - thanks for that. Something so simple and I'm freaking out over here. Where is my x-acto knife.
    Intex 14' x 42"
    philc's Avatar
    Jul 2015
    190
    My pleasure, here's a thread that may help. http://www.troublefreepool.com/threa...-in-your-Intex
