Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Is this a good price for 12.5% liquid chlorine?
    A few questions:
    Pool store is having a sale and has the 12.5% on sale for 4, one gallon containers for $14. Is this a good price worth stocking up?
    Also, I noticed that they also have the powdered stuff (no di-chlor or tri-chlor like the powdered shock I usually see) - what is a good price for those one-lb. bags? All chemicals are 25% off, so I thought it might be a good time to stock up. Does the powder stuff have a good shelf life?
    Thanks again!!
    27' AG round pool; vinyl liner; 1 HP pump; 40 GPM Tagleus sand filter
    Mar 2009
    Glendora, California
    169
    Re: Is this a good price for 12.5% liquid chlorine?
    I've seen 12.5% LC 2 gallons at walmart for $10, so that seems like a good price. I think I get my 6% bleach for about $2.50 per, I forget the size of the containler but I think it's bigger than a gallon. So compared to bleach I'm not sure how good a deal it is.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by queenofmyswamp
    A few questions:
    Thanks again!!
    The powder shock that is not dichlor is either MPS or Cal-Hypo. MPS is better for indoor pools. As for using Cal-hypo, with a vinyl pool, you don't "need" calcium, but low levels won't hurt anything either. You should have a CH test done to see what your level is and then decide that way if you want to use it, because you certainly wouldn't want the CH level to get too high. The shelf life for cal-hypo is better than 10-12.5% which will degrade in a rather short period of time, especially if stored in light/heat. The liquid should be stored in a cool dark place, and used within a few months. Price on the cal-hypo, depending on the percentage I've seen it as low as $2.99 a bag up to $4.99 a bag. Just depends.
    That $14 price is $3.50 a gallon which is good. When you say stock up, unless you have an algae bloom, I wouldn't buy more than 4 jugs to start with, see how long that lasts you.
    Feb 2008
    Milford, CT
    333
    Local to me, the 5 gallon carboy is 22.99 with the 6.00 deposit included (so, 16.99 for 5 gallons). Thats the best price Ive found for it, and its only slightly better than your price.
    Carrying 4-1 gallon bottles around is probably easier.......and its DEFINITELY easier to pour.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    May 2009
    Jasper, TN
    249
    A few questions:
    Thanks again!!
    What store is having this sale?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    I thought i might be buying something different because i pay 1.99 gl, but no 12.5% is what i got i buy mine at In The Swim or a local place called Cada pools.
    24'x52" ABG Around 13,000 gallons.
    Hayward Star Clear Cartridge Filter 1.5 hp pump 100GPM.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Anyone living in the midwest where there is a great escape pool store near by should look there, I bought 2 cases with 4 one gallon bottles in each for 9.97 each that is less than 2.50 a bottle...I don't think you can beat that...They are in Illinois, Indiana and One location in Ohio...Mostly around the Chicago land area...but if you live there...Good price.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I'm not sure if this is all leslie's or just the one closest to me, but they have "double punch wednesdays" so you get two punches for every one purchase on your buy 10 get 11th free chlorine refill. of course they almost always have a buy 2 get 1 free sale, but still.
    I've been getting my 12.5% bleach in 2.5 gallon containers for $8.90 each at a water store near me. Looks like that is a pretty good price.
    24' AG Pool, 52" Walls, Hayward Filter with Zeobrite media, 1.5 HP Pump
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by extremernc
    a 'water store'?
    Please explain.
    A few questions:
    Thanks again!!
    That's what I'm paying -- my local pool store charges $3.99/gal or 4 for $13.99, regularly.
    It's very very close to the same price per ounce of Wal-Mart brand bleach (after factoring in the larger bottles at lower solution). But I get it in smaller containers, and less possibility of it splashing on me when I'm putting it in.
    Hayward S220T Sand Filter, Hayward Max-Flo 1 HP Pump, 14,000 Gal Vinyl Inground
    Quote Originally Posted by rastoma
    a 'water store'?
    Please explain.
    Well I call it a water store because its not really a pool store but they do have chemicals for pools. I think i just confused myself! They supply chemicals and equipment for potable water systems for residential, commercial, industrial, and municipal applications. They are the largest supplier of industrial bleach in eastern North Carolina.
    Heres a link to explain further: http://waterguardinc.com/
    Hope this explains it!!!
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I am new to the Dallas Fort Worth area, does anyone know a good supplier of 12.5% LC around here. Using the Sams club 6% at the moment.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Arizona
    924
    $11.99 for 4 one gallon jugs of HASA 12.5% at my local B & L Pool Supply. I think I'm pretty lucky.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    May 2009
    Seminole, FL
    71
    Chlorine is cheap here in FL compared to what a lot of you guys pay. Local pool stores have it for ~4.50 for 2.5 gallons of 10.5% chlorine. Thats about $1.80 a gallon. Compare that to 6% bleach and its ~$1.10 a gallon.
    ~13000 inground plaster
    150sq Ft Cartridge Filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    yeah I can't believe all these places that have such expensive chlorine, or places like texas who don't have it at all. crazy. and the chlorine here used to be $2.49 for 2.5 gallons in 2006. leslie's just lowered their price to match pinch a penny at $4.25. where do you live?
    May 2009
    Seminole, FL
    71
    I'm in Seminole, FL (St Petersburg).. Yeah you are right its $4.25 for 2.5 gal from Pinch a Penny or Leslies here.. we have some other stores in the area as well not sure how much they charge.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Quote Originally Posted by AV8TOR
    Hi AV8TOR. I didn't realize you were in Texas! Well, there's another thread where we're trying, here in Texas, to find some 12% with no luck so far. And the one place I've found that sells 10% for cheaper than Lowe's (which is $4.98/gal) is a supply place in Garland, which sells 4 gal for, I think, around $13. It was a little over $3 per gallon, which was computed to be pretty high compared to the 6% price at Wal-Mart. But our Wylie Wal-Mart no longer sells the Ultra, which was $2.63 for 182 oz. They're carrying a different brand now that runs $3.98 for the same 182 oz So the Garland supply place is definitely cheaper for us now, given that it's 10%.
    I'm still trying to find some 12% and will be happy to let you know when/if I find some.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    It's been awhile since this thread has been visited. Any luck finding 12% in TX? ...I'm in the Dallas area.
    13,500 GAL half buried Doughboy AG Vinyl, 24' Round, DE filter
  20. Back To Top    #20
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Hi feifer! It looks like most of us in the DFW area are the ones on this thread...probably because Texas doesn't allow the sale of 12%. Or at least that's my understanding so far. The places I've called only go to 10%. The cost of the 10% appears to be a little bit higher than the cost of the 6%. So I think what it comes down to is, is it worth it to you to pay a little bit more to NOT have to haul as many jugs of chlorine back home and out to the pool? It would still be much better with the 12%, since that would cut the hauling in half!
    I plan to make the trip to Garland for the 10%, since it's not that far from Wylie. I don't know what part of Dallas you're in, and Dallas (as well as Garland) are quite big!
    Maybe we can create some type of co-op and have some 12% (or higher) purchased just beyond the Texas border, then bring it in! But that may end up being cost-prohibitive since all the Texans who've inquired are not close to the border.
    So far this season, we've only been needing 1 to 1 1/2 qt. of 10% each evening, which is not all that expensive. I'm hoping if someone finds some 12% somewhat close to our area, that they will chime in and share the info!
