Thread: Raising Intex Prism frame supports (metal Fame rectangular pool)
    May 2016
    NL
    4
    Hi,
    I have a question regarding my new Prism frame retangular pool 5 x 3 Meters. I am planning to set it up on my terras/driveway but it is not fully level.
    Maximum of 7 cm off (2,5 inch) over 5,5 meters
    Now i was thinking about raising the supports a bit So leveling the frame, but i am afraid that the frame will cave in as seen on a youtube movie of a metal frame pool, which had all support beams 3 inches to high (the guy forgot to burrie these level with the floor) But i dont know if this also happens when raising the supports to fully level but not the floor.
    Leveling is not an real option, because its my behind driveway (paved) and i need to remove the pool in a few months due to the winter.
    Maybe other level options such as thick shingles?
    Bart
    May 2016
    Peabody
    2
    Re: Raising Intex Prism frame supports (metal Fame rectangular pool)
    1. The area where the pool is to be set up must be absolutely flat and level. Do not set up the pool on a
    slope or inclined surface.
    May 2016
    NL
    4
    The max incline is 2 degrees if im not mistaken this meand 18 cm over 5 meters..
    Casey's Avatar
    SW PA
    10,448
    You really want this pool to be on a level surface. If this is the only place you can put it, you can try to box it in with a frame and add limestone/sand to build it up.
    May 2016
    NL
    4
    yes, that was my idea now, indeed make a wooden sturdy frame on the floor and put in grit to level, and add intex foam tyles on top
