Thread: Hayward Superpump 115/230
    Kannapolis, NC
    89
    So a little mad at self for not taking time with project and I have made a mess of things
    I began hooking up the power to the motor and in the process, I ripped some wires loose to be exact the black jumper.
    I took said motor to some guys at my work and they got it working without the plug.
    But now when it is up and running clicks clicks clicks
    _________________
    My Pool:
    Foxx Pool Grecian style 19' X 39'
    27k, with a 300# sand filter
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Hayward Superpump 115/230
    I wouldn't run the motor without a thermal limiter as it could cause the motor to burn up.
    Does this look like it might be the wiring diagram:
    Mark
    Kannapolis, NC
    89
    when I get back home will check
    _________________
    My Pool:
