Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: I need help with my swamp.
    Apr 2016
    Edgewood, TX
    21
    I have my TF-100 XL ordered and I'm slowly working on getting the debris out of the pool. My pool is currently a frog habitat. There are hundreds of tadpoles swimming around in it. The pool was used last summer. It's an unground Doughboy. 15,000 gallons. Deep end is around 6 feet. With 3.5 feet shallow and around the perimeter. Vinyl liner. Cartridge filter. Jandy Pro Series CL 340. There's a giant sweet gum tree that's been dumping all it's leaves and such in the pool since the fall. The pool is very green. I will attach pictures once I figure out how to do so from my phone.
    Right now I'm just using a leaf rake to clean the pool and it's not a fast process. Is there anything I need to do before the kit gets here? Or anything that would make this process go quicker?
    Thank you!
    Mod note: I merged your two threads. It is much easier for us to help you if we have the whole story together. Kim
    Jun 2014
    15,298
    Re: Frog Habitat
    Hello and welcome to TFP! You have the right idea ... manually clean, clean, clean. The more the better. No sense trying to guess what chemical levels are needed at the moment. You might even have an ammonia issue in there which we will guide you through later when the kit arrives. Stock-up on bleach, make sure your immunizations are up to date (KIDDING) , and read the SLAM page a couple times.
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post.
    Great to have you with us!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Frog Habitat
    Welcome!
    A leaf bagger
    Leaf eater - how well do they work? is, I think, the most recent thread discussing them.
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    I got my leaf bagger in and tested it tonight so I could get a feel for how it's going to work. I plan doing lots of cleaning tomorrow as long as the weather holds out. Do I need to test the water now or wait until I get it cleaned up more?
    Richard320's Avatar
    Jan 2010
    19,075
    Re: Frog Habitat
    Quote Originally Posted by krbryant22 View Post
    Whenever the water has been well mixed you can test. Running that cleaner around should help keep things stirred up.
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    Still getting leaves out but here's my test results.
    FC .5
    CC 0
    TC 0.5
    CH 225 ppm
    TA 70
    CYA - I filled the tube up and I could still see the dot.
    Jun 2014
    15,298
    Re: Frog Habitat
    So we know you need to do a SLAM now correct? We need one more test result ... the pH. Did you do that one (red drops)?
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    Yes. 8.3. Very acidic. I'm still worried about ammonia. I'm guessing starting the SLAM will let me know if that's an issue.
    Jun 2014
    15,298
    Re: Frog Habitat
    Okay, then here's what you need to do:
    1 - Lower pH with acid to about 7.2. Check about 20 min later with pump mixing to confirm change is good
    2 - Before adding any stabilizer, do the 10-min drill ... perfect if it's cloudy at your place like mine today - we're checking for ammonia
    2a - Raise FC to 10; check every 10 minutes. If it drops below 5, raise it to 10 right away again and keep doing this every 10 minutes
    2b - Once your FC holds over 5 or close to 10 after 10 minutes, add granular stabilizer for a CYA target of 30 and increase FC to "12"
    Now you're SLAMming! Check FC consistently to ensure is stays at 12. Let me know if you have any questions.
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    Thank you.
    Jun 2014
    15,298
    Re: Frog Habitat
    You're welcome! Let us know how things turn-out. Hopefully in a short time frame, you'll be past the 10 min drill and moving on to your normal SLAM (CYA of 30 and FC of 12). If you or your frogs have any questions later, let us know.
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    Went out today and there was a tiny turtle on the second step that took off into the depths before I could grab net to fish it out. I think I'm going to keep vacuuming this week and start the SLAM on the weekend. I don't want to start pouring ton of chemicals in until I get as many critters out as possible. I'm grateful I have a couple of ponds so that I can re-home them.
    Jun 2014
    15,298
    Re: Frog Habitat
    You have a good heart. I had a water garden at one time so I understand. When you start the SLAM, if you have any questions, let us know.
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    I've started the slam. Adding three gallons at a time. I'm holding steady at .5 FC and CC. I've noticed a change in color after the last time I've added bleach. Do I just keep adding bleach? I just put more in and plan on checking on it in the morning. I'm up to twelve gallons.
    I have a 15,000 gallon in ground vinyl pool.
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Re: Frog Habitat
    I get frogs frequently in the skimmer, the live ones go back in the garden..........but then again, I should toss them over the wall because they could be what the 2 Cobras were after..........I have taken 2 Cobras out of the yard and the third snake was so fast, I don't know what kind it was
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Frog Habitat
    How did the 10min test go?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Frog Habitat
    You say you're removing cobras from the yard like it's no big deal.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    I haven't got the FC up high enough to do the 10 minute test yet. I had doctor's appointments all day today - took longer than expected. I stocked up on more bleach though.
    Apr 2016
    Edgewood, TX
    21
    Re: Frog Habitat
    Just tested the water again. Still showing .5 on FC and CC and I never got the FC up high enough yesterday with 12 gallons of bleach to do the 10 minute drill. The CYA tube still has a visible dot all the until the tube is full. Do I need to add stabilizer before continuing with bleach or should I go hard core on the bleach?
  20. Back To Top    #20
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Frog Habitat
    Sounds like ammonia to me. I would definitely not add CYA until confirmed.
    e: 10 minute drill is the best way to eliminate. 10 minutes, test, add; 10 minutes, test, add; etc.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
