Thread: Intex Filter Leaking BAD at Leaf catcher when not running.
    May 2016
    Cusseta Al
    3
    Sunday we hooked the Intex sand filter to our pool small leaks but few adjustments was fine until Sunday late I turned the pump off. Stared Leaking BAD at the leaf catcher, (Note does not leak when running) So far as of today its leaked almost over 2 inches of water from pool. I ended up having to Close the Valves off on the pool. both intake and return. Any suggestions why this happening ?
    Coleman 16X48 Above Ground Power Steel Framed Pool.
    With Intex Sand Filter Model# SF20110
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Intex Filter Leaking BAD at Leaf catcher when not running.
    There is something wrong with the leaf catcher. It is typical that suction side leaks, leaks between the skimmer and pump, only leak when the pump is off. When the pump is on there is enough suction that it prevents water from leaking out and it usually sucks in enough air that it may cause the pump to lose prime.
    As to the specific leak, it could be a crack, loose plug or bad seal/gasket. Can you pinpoint were the water is leaking from? Is it the pump strainer or do you have a separate leaf canister/catcher? A picture is worth a thousand words or in my case about 20 minutes of typing
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    38,305
    I am not sure how you did it, but your last 2 posts that appear to be trying to post a picture are corrupted. I have deleted them.
    May 2016
    Cusseta Al
    3
    Trying to post a pic of my pump/leaf catcher to show where it is leaking? New to site not sure how to post pics?
    May 2016
    Cusseta Al
    3
    Quote Originally Posted by Pool Tool View Post
    Thanks, I'll look at the seal/gasket when I get home. I'll take pics so that it will explain more.
    38,305
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
