Thread: Pool circulation and pump motor rebuild
    May 2016
    Walla Walla, WA
    22
    How often do most people run their pump/filter? Mine is not set up with a timer and I believe the previous owner ran it 24/7. I would like to set up a timer for the 1HP sta-rite motor and flow max pump. Any recommendations on timers and run times?
    Also, has my motor sounds like a Cummings diesel at the moment. Has anyone ever put new bearing and seals in their own motor? How much of a project was it? Thanks!
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Pool circulation and pump motor rebuild
    There's a great article on pump run time here: Pool School - Determine Pump Run Time
    I'll let an expert answer your rebuild question. My pump/motor sounds pretty rough too.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2016
    Walla Walla, WA
    22
    Quote Originally Posted by triptyx View Post
    Thanks for the link! As soon as I finish my SLAM process I will be giving that Detroit a rest for a bit - or at least when I am trying to enjoy the pool.
    May 2016
    Walla Walla, WA
    22
    I had a pool store owner tell me yesterday that he wouldn't recommend installing a timer for my circulation pump. His reasoning was that your money can either be spent on power or extra chemistry to make up for lost circ/filtration time. At least with the pump running 24/7 the water will be more aesthetically pleasing. How do you all feel about that statement?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    That statement makes no sense, it's not an either/or. I have a Intermatic 104 on my pump, set to run from 2-6pm so that if I want to have pool time after work it is skimmed when I get home during the week. In 3 years I have never had cloudy water beyond pollen which is easily filtered out. Some people have theirs set to run at night to take advantage of cheap electricity.
    There is no sense running a pump 24/7 unless you are SLAMming.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mar 2013
    CT
    351
    I've never run my pump for more than 8 hours a day - unless SLAMMING - and I dont think my water could be MORE aesthetically pleasing.
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
