Thread: Leak by gasket where skimmer is located
    May 2016
    Hopkins South Carolina
    14
    I have 2 very small drips coming from my skimmer on my pool. The pool is a 19󭅉2 intext vinyl above ground pool. I would like to know if there are some adhesives or something that I can use to plug the leaks without having to go thru the whole process of taking everything apart and replacing the gasket. If there is anything I can buy please let me know
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Leak by gasket where skimmer is located
    Sorry, but no. If snugging things up doesn't dry up the leaks, it has to come apart. Laying a bead of something around the outside will just cause the leak to shift to a new spot, and then you'll have to clean off the mess when you get around to fixing it right.
