Thread: Acid question
    Dec 2015
    Newington, Connecticut
    113
    Acid question
    In reading a lot of the posts I see that most are adding acid on a regular basis while practicing the top methods. While using tricholor last season I was always increasing ph and alkalinity. I'm finding that I will most likely be doing the same this year while using bleach/ liquid shock for sanatizing. My levels are starting to trend down now that the water temp is increasing. Been raining a lot as well which is probably lowering ph and alkalinity.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
    Aug 2014
    Northern IL
    4,615
    Re: Acid question
    Hi, Andrew! Welcome to the new swim season! Not sure what the acid question is...
    Jan 2012
    'burbs of Augusta, Georgia
    7,366
    Re: Acid question
    Some folks with new plaster pools are often adding acid as their pools "cure". Others who have SWGs may find the process raises their pH so it requires acid to lower.
    Trichlor and Dichlor are acidic and were probably keeping your pH lower.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Acid question
    Rain usually raises PH through aeration. Each pool is different and fill water, rain water and evaporation rates vary by region. Lots of folks have high evalopation rates and relatively high TA in their fill water necessitating acid additions as well. In your area with plenty of rain and not all that hot I would not expect your PH to rise as fast, if at all, as someone in the southwest.
