Results 1 to 7 of 7
Thread: Intex Pump adequate?
    May 2016
    Keystone Heights,Fl
    3
    I have an intex ultra rectangular 18x9x52 pool that came with a 1/4 hp pump. Doesn't clean very well. Should I upgrade to a 1/2 hp? Is it easy to switch out?
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Re: Is intex pump adequate?
    I think the biggest improvement is going from the cartridge filter to the sand filter. Seeing the fine dust blow back into the pool via the return used to be very aggravating.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Aug 2013
    south east Arizona
    200
    Re: Intex Pump adequate?
    Very easy to switch - get the biggest you can afford - and go sand. If your hoses are 1 1/4 you will need a couple of adapters but you should get new hoses with the pump and filter.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    Apr 2016
    Casa Grande, AZ
    66
    We have the same pool and so far I must say it hasn't been bad - run it 6 hours a day and our water is crystal clear for about 2 weeks now - I do wish it had the power to run a vacuum as I have mentioned in other threads - but the water itself is pretty dang clear!
    Intex 18'x9'x52 - 2800 GPH Sand Filter/Pump - TF100 Test Kit
    May 2016
    Keystone Heights,Fl
    3
    Thanks for your suggestions. I already have a sand filter and I run it 6-8 hours a day. It is clear but has very little suction. I've had the pool for a year now. Just installed a hayward through wall skimmer and want a little more suction.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Welcome to TFP!
    How does the clean pressure compare with last year? Maybe it is time for a deep clean, here's how, Deep Cleaning a Sand Filter
    May 2016
    Keystone Heights,Fl
    3
    The pressure is the same. I also backwash it at least once a month.
