Results 1 to 8 of 8
Thread: Chlorine FAS/DPD Test
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    Bought the TF-100 test kit and seems like the chlorine FAS/DPD powder is going very quickly. No way I will get approx 75 tests from the amount that came with the kit. Directions state heaping scoop but I have been dialing back since I am doing a SLAM right now. Should I use smaller scoops? Just can't see this lasting much longer at this rate of 3-4 tests daily.
    33K, IG, vinyl liner, 15 years old (??), 20x40, 3-8 feet deep, Hayward pump 1.5 HP, Hayward S240 sand filter (300 lbs of sand), Dolphin Triton robotic cleaner, TF-100 test kit.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Chlorine FAS/DPD Test
    as long as the water in the test tube turns pink and there are a few chunks left in the bottom you are good
    Jan 2012
    'burbs of Augusta, Georgia
    7,334
    As you are doing a SLAM, use 10 mL of pool water and 1 rounded scoop of powder. You should be able to perform accurately with that. Each drop of 0871 reagent is counted then multiply by 0.5 (or just divide by 2, lol)
    Go ahead and order more test reagents now as you've got a lot of summer ahead to test
    38,274
    That is why we generally recommend the XL option when you know you have a slam to do. At higher FC levels you also need to use more powder than you will when you get down to maintenance levels.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    Get the Taylor Replacement Reagent R-0870-J DPD Powder .25-Pound by Taylor Technologies on Amazon for $29.00. That's a little over 11 10 gram containers.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    Thanks guys!
    Rocket50's Avatar
    Apr 2016
    Nashville, TN
    64
    Quote Originally Posted by ned8377 View Post
    Does the powder have a limited shelf life? That might be a few years of testing.
    38,274
    Depends how it is stored and how old it was by the time you get it. Should be good for close to 2 years.
