Results 1 to 10 of 10
Thread: Secondary filter for iron
    Apr 2012
    151
    I have a pool I am trying to clear, but it has high iron. Every time I add chlorine, it turns brown. Read on another forum a method of taking a submersible pump and routing the output through poly batting after shocking to filter out oxidized iron. Is this feasible?
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    30,403
    Re: Secondary filter for iron
    It all depends on the amount of iron you have. If your fill water is heavy with iron, it will just keep coming back.
    Test your fill water and post back with that result.
    Generally, a mechanical filter does not work well with iron but there is always a chance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    You can stuff some polyfill in your skimmer baskets and see what happens. It definitely won't make it worse!
    Apr 2012
    151
    The polyfill was the idea, using another pump. At this point the homeowner is chomping at the bit to swim. It is BAD. I know it is the fill water - did a liner up the road (same water association) and had to use a sequestrant in the first 1000 gallons. This pool is fiberglass and has not been emptied in 12 years, filling from the same high iron fill water.
    I will have test results tomorrow.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    A greensand filter might be able to remove some or all of the iron in the fill water for the pool. A reverse osmosis filtering of the pool would work too. Both are on the expensive side of things tho. Iron is one of the most difficult things to remove from water.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Msu moose, are you from MSU?
    You might consider trying on of these attached to the return...be sure to tell homeowner to get the return fitting as well.
    I haven't used it but I've seen several reports that it helps a good deal. Pro s that home owner could also use it to pre filter a bit on fill ups.
    The Slime Bag | The Easiest Way To Maintain Crystal Clear Pool Water.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I've always been tickled by the low-tech use of polyfil and/or plain old paper towels in the skimmer to help collect iron. Low budget and it doesn't add anything to the water. It might not work entirely but it might be worth a try if just to lower it some, right?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    When its oxidized, just about anything can catch some iron.
    But generally in water tech world, filtration below 5 microns removes more.
    Slimebag is 1 mcron, ergo, would capture more.
    Helpful Links:
    Apr 2012
    151
    So just did a test (regular not metals)
    Free Cl 2.0
    CC < .5
    TA 150
    pH 7.4
    CH 75
    CYA 80
    Iron and copper test arriving via FedEx tomorrow.
    Made a filter. It is working pretty good. Catching some stuff, but I am sure it is not enough.
    I have 5 lbs of citric acid for the brown pool walls, but not being able to SLAM is frustrating.
    Apr 2012
    151
    Iron between .3 and .5 . Adding metal sequestration
