Thread: fill water has iron
    monkeywrench's Avatar
    May 2008
    Shrewsbury MA
    fill water has iron
    Hi all,
    It's good to be back at TFP again, it means that the heat will soon be hear,I've been gone since the fall spending time in a coal heating forum trying to learn how to get some heat on the inside, now I'm ready for some heat on the outside! I'll be opening soon and I plan to fill from the hose again but have had some problems with metal stains in the past ( pre TFP) This year I closed with some metal free and was wondering if I should circulate in some more prior to filling to head off the staining or does it matter pre or post fill?
    Any way is good to be back, I hope to be able to contribute again in any way, especially mechanical, electrical and masonry
    14x28 IG Vinyl
    12.5k gal
    Hayward SP-Super Pump
    Hayward Pro-Grid 36sqft DE
    Hayward auto chlorine feeder (offline:using BBB)
    Hayward AG Gas heater
    Re: fill water has iron
    I would add another dose of sequesterant when you open and before you shock. As a general rule you will want to add seqesterant every time you add more iron containing water and you want to add maintenance doses of sequesterant monthly to weekly, depending on how bad your iron problem is. I would use a HEDP (Phosphonic acid derived) based seqesterant and not an EDTA based one like MetalFree.
    Proteam Metal Magic, GLB Sequa Sol, and Jack's Magic Pink or Blue stuff are all good (Pink stuff is better for Iron than Blue stuff but either wiill work!). There are other good ones too. Read the label and look for HEDP, Phosphonic Acid Derivative, or phosphonate.
