Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Refinishing slide
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Refinishing slide
    After getting a quote to repair my slide professionally, $1500, nearly the price of a new one, I've decided to tackle refinishing it myself. Using this thread as a guide and inspiration: Refinishing / Restoring a Fiberglass Pool Slide
    My slide is the same or very close to the slide in that thread. The SR Smith Rogue 2 or Grand Rapids. Time to start sanding and getting supplies ordered. Going to be using the Interlux Perfection 2 part epoxy paint as in the inspiration thread. We'll see if I find time to get it done. Pictures to follow of course once I start into it.
    Isolated Spa - 345 Gallons
    38,475
    Re: Refinishing slide
    I have been watching that thread for a LONG time. My slide is getting to the point where I should do this as well. Interested in watching your transformation
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Now I know why I don't have a slide! Interesting process.
    Mar 2016
    Easley, SC
    381
    I have the same slide that needs to be refinished. The previous owner took the slide down and tossed it down a bank in the woods. I recovered it but have not found any of the supports or ladder. The slide is in perfect condition other than the finish is flaking off. Once you get your slide taken down could you do some measuring on the supports and ladder for me? I honestly have nothing to go by at this point. Look forward to your process as I hope to start on this project later this year.
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    Feb 2014
    Central Minnesota
    5,080
    I actually did measure the supports to maybe cut some lengths of PVC so I could set up the slide in my screen porch. I can post the heights of the posts measured from the pool deck. I was surprised by the ladder. When I took the slide off the supports, the ladder doesn't wiggle, budge at all. There must be at least 6 inches of ladder into the concrete...
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    Quote Originally Posted by JVTrain View Post
    That's awful news. Who did you get the quote from? My slide was in awful shape last year and in my research, I called marine body shops to see if they were interested in some work (With all the water in Minn., they must be fairly prevalent) After all, it's not much different than repairing a fiberglass boat. I had my slide redone for $700.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Mar 2016
    Easley, SC
    381
    That would be awesome if you dont mind. If you could measure the support diameter also? What type of PVC would you use? I figured it would have been steel posts?
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Husky25 View Post
    Glad yours worked out well. I think I can do it for about $300 is supplies and my labor of course. You would think there would be a lot of marine places that do hull work around here, but it seems there's not many that do actual refinishing. Lots of dealers and service places but not many fiberglass experts. If I were in the Minneapolis/St. Paul or Duluth areas, there would likely be more resources as those locations have yacht clubs, marinas and more sail boats which makes repair more in demand, I would think.
    Quote Originally Posted by joshua5438 View Post
    I was only going to cut lengths of PVC I had laying around to use it as temporary posts to hold it up while resurfacing the slide, rather than doing all the work right by the pool. I'll probably just end up using saw horses and a portable work table I have. I believe the OD of the aluminum? posts is about the same OD as 1.5" PVC, which is about 2 inches but I'll measure exactly.
    38,475
    I would not trust PVC pipe (especially 1.5") as the support for the slide while in use ... too flexible.
    Husky25's Avatar
    Jun 2015
    465
    Good luck, Train. Hope it works out. I'm real interested in whatever photos you post.
    Chris
    Feb 2014
    Central Minnesota
    5,080
    What I haven't decided on is the underside of the slide. I think I'll just be giving it a thorough cleaning and laying in some epoxy in the areas where the fiberglass mesh looks a bit more exposed and around the ladder fittings...
    Feb 2014
    Central Minnesota
    5,080
    WARNING: MASSIVE PHOTO DUMP AHEAD
    Not so sure on the brand of slide anymore even though it looks like the old SR Smith Grand Rapids, the supports are not the same as the pictures I've seen of that slide. Mine has a bent support on the bottom inside curve, where the SR Smith slides have straight vertical supports:
    Plus this from the bottom of the slide. Search for Fibre Slide on the internet yields a foreign company, playground slides only:
    Here is the supports layout wide view, slide and railing removed:
    Photos before power washing... hate my pool decking in that area!
    After some power washing at the top of the slide. The difference is amazing already:
    Problem area on middle center of slide. Some spider-webbing of the topcoat. There are a few chips here about pea size (like in the upper right) where you can see underlying fiberglass but no cracks or breaks:
    Full view after power wash. Bottom looks a lot better too but forgot to take a picture:
    Feb 2014
    Central Minnesota
    5,080
    I have dimensions of posts for joshua, if you still think your slide might be the same. Referencing the third picture in my previous post:
    Lower 2 posts are 19 inches apart on center
    Shorter bent post is 21" tall from pool deck
    Taller bottom post is 24" tall from pool deck
    Middle post is 45.5" tall and is 38" on center from the lower, straight, taller post
    Ladder is 72" long from pool deck with about 4 inches going into the pocket on the bottom of the slide.
    Ladder rails are 2 7/8" x 1" rectangular with a 20" spread.
    The OD of the support pipes is 1 7/8" and they are aluminum.
    38,475
    Looks very similar to my slide, although I think I have 2 additional posts at the top, so likely my ladder is not load bearing, or at least not as much as yours is.
    Mar 2016
    Easley, SC
    381
    Awesome.. Thanks for the dimensions! I know that my slide had straight posts at the bottom as I can see where the bolts were cut off flush on the pool deck. Those numbers will give me a good reference for starting the process. I need to pressure wash mine but from looking at the bottom side I do not see any branding like yours has. keep us posted on the process. Looks like you have very little work to do to get it ready for paint.
    Feb 2014
    Central Minnesota
    5,080
    Filled some in the bare fiberglass spots on the underside with bondo resin. Sanded and filled the topside chips with 2 part epoxy. Then sanded the whole slide for nearly 2 hours. 80 grit to remove scaling. Probably still more to do in the difficult to sand inside curves.
    Feb 2014
    Central Minnesota
    5,080
    Lots of work on the slide today. Sanded inside curves with a sanding sponge. Skim coated resin on some bare spots of fiberglass on the top. Sanded again with 220 grit over whole slide. Rinsed with water. Washed with soap. Wiped down with acetone. First coat of two-part poly paint.
    Interlux Perfection in Lauderdale Blue.
    First coat was tricky getting used to rolling it on then tipping it off with a brush. Definitely can see where I stopped/started and overlaps.
    Not too bad for first coat will do some sanding on the poor paint job spots, then another coat. Only took about a cup of mixed paint to cover whole slide easily.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    I am so NOT showing my husband this thread! LOL He has always wanted a slide! That is look awesome!
    Kim
    Mar 2016
    Easley, SC
    381
    Looking good! Where did you get the paint and what type of brush/roller are you using?
  20. Back To Top    #20
    Feb 2014
    Central Minnesota
    5,080
    Got the paint at Jamestown Distributors: Interlux Perfection Using a 3" roller with 1/8" closed cell foam nap. Also using a 2" tapered polyester brush to tip off the rolled paint. I might pick up a badger hair or other natural hair brush for the second coat. Not sure if it will make it easier or get a better finish.
    There are EXCELLENT instructions on their website and with the paint on how to apply. Even some youtube videos starting here Interlux Perfection Topside Boat Paint Howto: Introduction - YouTube
    I did not apply a primer coat or use any of their thinning agents on the paint. Clean up on brushes is with acetone so wooden handles on brushes is best.
