Thread: New Pool Owner
    May 2016
    Wickhaven, PA
    1
    Wink New Pool Owner
    I am putting up a new above ground 18X48, I am using city water to fill it, what should I do first? I was going to buy a start up kit, is that a good idea?
    Thank You,
    Marie Bolen
    Jun 2014
    15,096
    Re: New Pool Owner
    Hi Marie! First thing ... the right test kit. See the TF-100 link in my sig below. EVERYTHING you do to that water hinges on YOUR testing. Don't fall for test strips or pool store testing. Next, read the TFP Pool School pages. It doesn't take long but you need to know it. Once the water is full, you can expect to do the following:
    1 - Start soaking stabilizer (CYA) for an initial target of 30 ppm
    2 - Add regular bleach for a day 1 target of about 3 ppm; once the stabilizer from step 1 dissolves, increase to about 4-5 ppm
    3 - Test and adjust pH to the mid 7s.
    That's a very basic start. But once you get the right test kit you can post a full set of numbers for additional details. Hope that helps. Welcome!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New Pool Owner
    exactly what Pat said, welcome to TFP great start, now you won't be pool stored
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: New Pool Owner
    Welcome to TFP and congrats on the new pool!
    Casey's Avatar
    SW PA
    10,438
    Re: New Pool Owner
    Welcome. Read ABC'S of pool water chemistry and order a TF100 for starters and ask questions.
