Results 1 to 7 of 7
Thread: new Safari browser...
    Anyone running the new Safari browser from Apple yet?
    Are there problems with certain apps not running in Safari, like with Firefox? I have FF 2.0.0.4, the newest upgrade, and occasionally, I have to use IE for something... not often, but still a PITA...
    If it ain't broke.... but I feel the need for speed!!! My friend says it is way super fast compared to IE.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Grace, does the text on the homepage look large to you with Firefox? It looks normal on IE but I've been told by a couple of firefox users that the text in the intro paragraph is too large.
    Of course, most people are using IE.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    I'm using the latest update of Firefox running on windows xp sp2 and the home page text looks just fine to me.
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    East Tennessee
    278
    I adjusted the text last week... It should look better now if every one clears their cache.
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    Quote Originally Posted by SeanB
    The intro paragraph text is much larger than the rest on the homepage. I have a small (15") LCD monitor and it is set to 1024x786, so all text is pretty small to begin with.
    East Tennessee
    278
    You can vary the text size by holding the ctrl key while scrolling the scroll wheel on your mouse if that will help at all.
    Steve
    Arizona
    924
    I haven't had a problem with the text in Firefox on my Windows system.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
