Results 1 to 11 of 11
Thread: First Home Water Test - what's the order of adding chem
    May 2016
    Bolingbrook/IL
    18
    Hi Everyone,
    I did my first water test using the LaMotte ColorQ7. Here's my first numbers:
    test
    now
    target
    resolve
    fcl/tcl 1.87/2.03 1 none
    ph 7.2 7.5 25 oz weight washing soda
    aly 142 90 none
    ch 132 300 add 197 oz calcium chloride
    cya 16 40 33 oz of stabilizer
    My pool is a 21' round vinyl AGP. So which stuff do I add first? and how long before I add the next item.
    Thanks everyone!
    10,400 Gallons AGP - Installed 5/2/16, Waterway Clearwater II Cartridge Swimming Pool Filter, Malibu 2 Speed 1.5hp Pump, K-2006, Rheem P-M266
    Aug 2014
    Northern IL
    4,615
    Re: First Home Water Test - what's the order of adding chem
    Hi! Chlorine should be first and you need some. CYA next, but aim for 30 only. Don't add the washing soda. Your pH is fine until we know how your water looks. Besides, if you wanted to raise it, you should use borax, not washing soda. The soda will raise your TA too. No need to worry about CH until you get that heater. . How does your water look?
    Your target is 3ppm FC with your CYA of 20.
    May 2016
    Bolingbrook/IL
    18
    Thanks @MarianParoo. It's my first pool and it's been 3 weeks since it was filled.
    As for chrlorine, I'm using the pool frog system. I have it set to 4.
    For CYA, I should put it in a sock and keep it by the skimmer?
    Aug 2014
    Northern IL
    4,615
    Yay! Put the sock in the skimmer. That's probably easiest. Remember to undershoot your dosage. Can you empty the frog?
    May 2016
    Bolingbrook/IL
    18
    I could empty the frog and just use itt when i go out of town or something. Dow you think a SWG is worth it?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, SWG makes life easier. No more buying and hauling bleach and adding every day or two. And, of course, no worrying about adding more CYA to your pool.
    Are you using multiple devices to post? Make sure the show sig box is checked on each one. Once checked it will stay checked.
    Aug 2014
    Northern IL
    4,615
    I personally don't have a SWG. Most people that do, love them. I don't mind testing and adding chlorine and I vacation at home in our swim season. A new heater last fall tapped my pool budget...
    May 2016
    Bolingbrook/IL
    18
    I bought a 25lb bucket of dichlor before i fiund this site. Can i use that to raise my FC and CYA. Once i get my CYA to 20-30 then use liquid chlorine?
    Aug 2014
    Northern IL
    4,615
    Did you ever add that CYA?
    Have you opened the bucket of dichlor? If not, can you return it?
    I realize that I didn't answer your question, but my reply depends on your answer... Also, what are your current test results?
    May 2016
    Bolingbrook/IL
    18
    I haven't added the CYA yet. It's at 22 right now. I've opened the dichlor and used it to increase the cya to the current level.
    Aug 2014
    Northern IL
    4,615
    That's fine! I am a dichlor user myself. You just need to understand that using it affects several variables at once. As for the frog, what pool frog do you have? Almost always they add chemicals that we feel are bad for pools. For vacations, there are safer alternatives.
