Results 1 to 14 of 14
Thread: Re-plumb for Vac
    Re-plumb for Vac
    Well it is spring and I am ready for a project. The dedicated line for the Vac was capped off when I got the pool so I can hook it up however I want. How exactly, do I want? =]
    So, Where should I run the Vac line? The return side? The Pump side?
    And how should I T it in to that line? My lines have Ts already and I will take a picture of that when I dig it up.
    Also should I valve any of the lines, like the step jets for better pressure/suction?
    -Nathan
    image source borrowed from KenJ
    -inBamaNow
    16x32 Hydra Liner, Hayward 24" Pro Sand Filter, WhisperFlo 1HP Pump, Hayward CL200, AquaChem Test Kit =[
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Re-plumb for Vac
    Quote Originally Posted by inbamanow
    It depends on your cleaner. Suction cleaners have to be connected before the pump. You should have a valve on it so it can be turned off when you want it off. Pressure cleaners usually have their own pumps, although some can be run from the existing pump. These would need the line connected after the filter, again with a valve for control.
    Hmmp, whay did I not include that I don't have a cleaner and will choose one based on what you guys tell me...
    I can go either Pressure or Suction with The Pool Cleaner and can't decide what is better. or possibly the Polaris 360/380...
    ARG
    Anyone want to tell me their preference... we get some pine straw, a few shruby leaves and sand/dirt/grass nothing too major as the neighbors removed all their trees.
    -inBamaNow
    Apr 2009
    Sarasota Florida
    143
    ARG
    Just out of curiosity where did you find your capped port? Terminated at the pad or buried underground? I need to locate mine and its not terminated at the pad.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Guest
    As a general rule of thumb pressure side cleaners perform better than suction side but most do need a booster pump so they cost more.
    The biggest advantage to pressure side is that they collect the junk in their own collection bag instead of sucking everything into your filter so this does extend your time between filter cleanings a bit (but you do have to empty the cleaner's bag!)
    Personally I prefer pressure with a booster pump, then, if you have the flow, boosterless pressure, and suction last. With a suction cleaner, even with a dedecated line, your skimming will be reduced a bit while the cleaner is running but with a pressure side cleaner you will always have full skimming power even with the cleaner running.
    Thanks waterbear...
    mdhwoods Mine was capped beside the sand filter, where they had a broken device that may have been some type of booster. It was a big plastic canister(coffee can sized) but it was very broken and old. So he capped that line , but left that device for me to ponder. Never by a house from some that promises to show you stuf after the closing. =]
    -inBamaNow
    I have decided to get a Suction Line Vacuum.
    So, when i re-plumb that PVC into the suction like do I use a T or should I do a Y junction. I'm not sure if it matters, but I would think a Y would be more efficient. Also, Should I put a Valve on the Skimmer side and the vac side or just the vac side?
    Thanks awesome people; My pool has been Clear and Blue for 7 days on BBB.
    -inBamaNow
    SW Indiana
    9,199
    I doubt you'll find a schedule 40 PVC Y. I've never seen one. I'd put valves in both lines so you can adjust suction as required for vacuuming.
    Hmmmp, that explains why I can never find the S40 Y... it might not be crappy local store... I always defaut to blaming the stores here.
    Thanks John
    -inBamaNow
    Well it was a bad day for me yesterday...
    I dug up the PVC infront of the filter/pump and found the one that was capped. I just off the cap and ran a snake down the line to find where it came out. I couldn't find where it came out it just hit something about 15 feet away. So I tried from the pool side to run a garden hose into the suction port, but it hits something even quicker(about 6 inches in) .
    I also tried pushing water each way with no luck. The water just comes back out each pipe.
    How are vacuum lines usually plumbed... They had a Hayward Navigator before...
    -inBamaNow
    Apr 2009
    Sarasota Florida
    143
    Sure your not just hitting an elbow? They can be a bugger to get a snake around.
    No... I probably am, but I still can't figure out why water won't come out...
    -inBamaNow
    Apr 2009
    Sarasota Florida
    143
    quite possible that the path of least resistance is to just flow back the way it came in. You would need to close off the end that you hooked the hose to so that the water can only come out the other end. That way it would either build pressure or come out the other end.
    Quote Originally Posted by JohnT
    Sure you can find them. It's just you're looking in the wrong place. Most local plumbing warehouses don't carry all these fittings. You need to find a commercial piping supply house or order online from a site such as this one: pvcfittings.com. They sell true wyes and full-flow wyes.
    There's really a lot of variety of fittings for schedule 40. You just might have to pay a little more for the specialty ones. The website above is really a great site. Just email any questions and they'll respond quickly and kindly. (Don't worry. I am not affiliated with this company in way ... yadda yadda. I just like their service.)
    20,000 in-ground pebble-coat pool with 60sf Jandy DE filter, Pentair Variable-Flow pump, Goldline Aquarite SWG, Dolphin Premiere robot, passive solar heating.
