Thread: Cloudy Pool - SWG Problem?
    May 2015
    Kent Store VA
    4
    Replaced cell about a year ago, worked great last summer. Shocked the pool and added salt about a week ago water is still very cloudy.
    Readings on the Aqua Rite Electronic Generator
    3.40
    21
    25.1
    5.61
    100P
    -3.30
    AL-0
    r 1.40
    Any help is appreciated!
    Jun 2014
    14,965
    Re: Cloudy Pool - SWG Problem?
    Matty, any chance you might have test results from a TF-100 or Taylor K-2006 you could provide? Also, can you clarify ... are you just re-opening your pool from winter, or has it been open year-round?
    One last thing ... please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post. Thanks!
    May 2015
    Kent Store VA
    4
    Ok after reading more into my settings I had somehow changed my readings to metric somehow. Now that Ive got that back to normal my readings look good.
    I have a 25000 gallon vinyl lined pool, sand filter.
    Anything else that would help?
    Jun 2014
    14,965
    Well, we still can't see your readings, so if you can post those it would help us. But often times cloudy water is indicative of algae. With algae, you'll find that FC diminishes quickly, and perhaps your filter clogs-up a little sooner than normal. If it is algae, then a "SLAM" (link below) is in order. The test results would help us with that. But they have to be from one of those reliable test kits.
    Jun 2011
    Long Beach, CA
    2,778
    According to the diagnostics the cell is working fine.
    You need to complete the SLAM process until the pool meets all 3 criteria for performing a SLAM.
    See the SLAM link in mine or Texas Splash's signature.
