Thread: Need help with possible stains on pebble finish
    bfoust's Avatar
    May 2016
    Spring, TX
    7
    New to forum. Have a one year old pool and see a lot of blotchy look on bottom of pool and edges where wall meets bottom. Not sure whether this is dirt staining or metal staining. I manage the water myself and have never tested positive for metals. I do have small copper scuppers. I did not know to use a metal sequestration product until now. Not sure the pool builder used in the beginning. Just looking for advice where to start to test stains. I notice a product online called Jack's magic stain test. Was thinking about trying that but wanted to learn more from others. Not really sure a one year old pool should have stains already. Thanks for help.
    Current stats
    Wet Edge Northshore Tahoe (Greyish pebble finish)
    pH: 7.4
    Total Alkalinity: 100
    Hardness: 225
    Chlorine: 3-5ppm
    CYA: 80
    Copper: 0
    Iron: 0
    TDS: 900
    Phosphates: 350
    Temperature: 80
    30,421
    Re: Need help with possible stains on pebble finish
    Welcome to the forum.
    Can you post a picture?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Other things can contribute to copper staining as well; algaecide, mineral/ion/copper systems, copper heat exchangers and PH under 7.0.
    Add your pool info to your signature so that we can better help you. More here, Pool School - Read This Before You Post
    This article might help you diagnose the problem, Diagnosing Pool Plaster Problems
    This stain ID kit might also help, Jacks Magic Stain Identification Kit JMSTAINID at Sunplay
    bfoust's Avatar
    May 2016
    Spring, TX
    7
    Attached photos. Really do not do it justice due to glaring and grey bottom. Let me know if this helps at all. Thanks.
    Pool Size: 32,000 Gal (AG)
    Pentair DE 60 Cartridge Filter
    Pentair Intelliflo VS Pump, Pentair Pump for Waterfall, Pentair Pump for Spa Water Edge
    Pool filled with tap water
    bfoust's Avatar
    May 2016
    Spring, TX
    7
    BTW - I also add a weekly dose if Natural Chemistry (Pool Perfect + Phosfree) to reduce phospates. I have an Ozone system on my pool as well and notice that when I add the Pool Perfect it gets sucked into the ozone area and distributed on the surface of the pool in bubbles around the return jet. It quickly goes away. it is a brown liquid and I wondered if it had anything to do with the discoloration.
    DFW, TX
    24,497
    I don't think pool perfect contains copper so probably not. Hard to tell from the pics. See if the article on plaster problems helps.
