Thread: Ladder cleaning
    Jun 2014
    Virginia Beach, Va
    23
    Ladder cleaning
    Going to clean and install my ladder. Will scrub the outside but it's sand filled, maybe 20-30lbs total.
    It was sitting outside full of water. Should I pour some chlorine in or am I over thinking.
    Current FC=7.2 / CC 0
    Successful slam, appears my SWG is working although the LED readout is not. Dealing in the run time and percent now. Thanks greatly for all your help!!!
    14,200 / AG / vinyl /Hayward S108T sand filter/Hayward 1hp sp pump /4 yr old pool / Taylor K-2006c / SWG AquaTrol RJ
    Jun 2014
    15,103
    Re: Ladder cleaning
    Actually, I was thinking if you could open the ladder/rungs, that would be best. Not sure how yours is built, but some ladders become absolutely inundated with algae inside. If water can get into or behind something, algae will try to find a home.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Ladder cleaning
    Check out the pictures in these threads:
    Problem Found and Ideas needed
    Water problems
    Jun 2014
    Virginia Beach, Va
    23
    Re: Ladder cleaning
    Tool the ladder apart and cleaned each piece. Just 1 1/2" Sq plastic hollow framework. Looking at it again can't be more than 10lb sand total.
    Will just re-assemble, and install and watch.
    Aug 2011
    Virginia Beach
    295
    Re: Ladder cleaning
    TFP has taught me well! I recently bought a plastic ladder from a neighbor who was decommissioning his pool. I knew it would have green water inside, as I could hear and feel it when I moved it. I took a drill bit to it and opened weep holes in all the steps, the sides, the top platform, and the top handles. I was not disappointed, they ALL drained slimy green, almost leafy debris out. I flushed it all with the garden hose, and I will be flushing with a bleach solution before it goes into the pool (if I ever get to open it this year). Has anyone else done similar, and or found a good way to keep the ladder chlorinated inside? I don't really want to go crazy with the drill any more than I already have. I'm considering some sort of "fill" hole near the top so it can run down inside and drain through the weep holes at the bottom.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
