Thread: Help.... looking for pool maintenance help
    May 2015
    Columbia, SC
    1
    Hi! I'm a "new" pool owner and have been able to maintain it myself for about two years. The problem it, I work over 100 hours/wk and about half the time, the pool doesn't look good. I'd like to find a local person or company to take over maintenance. However, I feel strongly about using TFP's method. Any recommendations on how to go about finding someone to help me?
    I'm located in Columbia, SC. I have a 18k (ish) kidney bean chlorine pool.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Help.... looking for pool maintenance help
    Welcome to TFP
    You need a salt water generator, it will help you more than you know... once set up its on auto pilot and you can teach someone to test in 20 minutes I also leave for weeks at a time and while not perfect I know it will be fine while I am gone...
    We can give you the info if you want
    here is a comparison chart Full Market Comparison of Salt Water Chlorine Generators for Swimming Pools
    Casey's Avatar
    SW PA
    10,448
    Welcome! As cowboy Casey says, you are a prime candidate for a SWG.
