Results 1 to 9 of 9
Thread: spillway dripping causing loss of water in pool
    May 2016
    wyckoff, nj
    4
    Hi I'm new here and hoping for guidance. Just installed a brand new pool (22x36 gunite, spa raised 2' with spillway). My understanding is that we have one pump that gets split between spa and pool. We lose 1" of water per day and that's without the heater on. PB came to pressure test all lines and noted no problems there. They think that the water dripping under the spillway is landing on the coping and directed away from the pool and, thus, causing the water loss. They tried drilling a channel under the spillway to redirect the water, but that did not work. What suggestions do you have to eliminate this dripping from the spillway. Note: we are unable to increase the flow from the spa because it will take away from the pool. I saw a few other posts on dripping/leaking and not sure if caulk would help and where it would be applied. Perhaps a different shape to the side stone of the spillway? Thanks for the help and let me know if I can provide any more info. See picture:
    Jan 2016
    Mesa, Az
    541
    Re: spillway dripping causing loss of water in pool
    Your photo didn't post
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    If needed, you can upload your pics to tinypic.com for free and without setting up another account.
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    May 2016
    wyckoff, nj
    4
    ps water runs at coping level to the left then to landscaping (I think)
    May 2016
    wyckoff, nj
    4
    Any ideas for me?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    You could use grout at a coping seam on the left, raised just enough to create a dam. (should not be noticable if grout matches).
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    May 2014
    katy. tx
    80
    can you take out the spillway and run the circulation thru the pool only for a day and see if the water level goes down?
    then same with the spa?
    that way you will know for sure if the spillway is the culprit.
    May 2016
    wyckoff, nj
    4
    Thanks for the idea... the picture may not show it too well, but the water is slipping in under the rock face too. I'm really hoping for a way to stop the water from rolling under the spillway stone for the practicality of it as well as the aesthetics. I will try the grout solution.
    I will also try to further evaluate the water loss source. I'm still trying to figure out my control panel/pool, so it may take a few days to have more info. Thanks
    Sep 2009
    Frederick County, MD
    185
    I am not sure what the "scupper" is made from but if water is rolling under it and dripping maybe is something small is glued on the width of the bottom slightly after the edge the drips will hit that and then fall down rather than traveling further back.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
