Thread: safety suction screen needed
    I have a 1 1/2" female bulkhead fitting that is unguarded.
    I was trying to located a screen cover that would thread into it.
    it is near the bottom on the sidewall.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: safety suction screen needed
    Not sure what size this is, but you could call them. GRAINGER APPROVED Suction Fitting - Pool and Spa Fittings - 2ZTT22ZTT2 - Grainger Industrial Supply
    Worse case you could buy an internal plug and drill or router some slots in it?
    Isolated Spa - 345 Gallons
    Jan 2015
    las vegas
    92
    First is determine the g.p.m. at the point of suction, then find the appropriately rated suction cover. Aquastar makes some hockeypuck style covers that should work.
