Thread: Hard Plumbing Advice
    May 2016
    Bolingbrook/IL
    18
    Hi Everyone,
    Here's what I have:
    - Waterway Clearwater II with 1 1/2" MPT x 1 1/2" Male Smooth Hose adapter
    - Rheem R266 with 2" x 2 1/2" water connections
    - Skimmer and return are 1 1/2"
    The plan is to install a heater bypass and hard plumb all the connections. Should I use 1 1/2" or 2" Sched 40 PVC for all plumbing?
    10,400 Gallons AGP - Installed 5/2/16, Waterway Clearwater II Cartridge Swimming Pool Filter, Malibu 2 Speed 1.5hp Pump, K-2006, Rheem P-M266
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hard Plumbing Advice
    Hey Mike, I used 2 inch and unless you really want to stay 1.5 inch I would say use 2 inch.. for the 1.5 connections in the skimmer and pump I used these
    21063-160-000 CMP 1.5 in. MIP x 2 in. PVC Hi-Temp Union- Nipples Unions Tools- 21063-160-00- Pool Products- WholesalePoolMart.com
