Thread: Hello from So. California - Pool Remodel
    May 2016
    Laguna Niguel/CA
    3
    Been lurking for a couple of months before starting a remodel on our circa 1989 pool. Tossed a coin between filling it in and the remodel as we live in an area with expansive soil and needed to demo the concrete deck. The remodel won. We have some relatively minor work to do on the gunite shell including a structural crack that will be repaired. Also pulled permits and found out we need to replace 100 feet of wrought iron fencing as it does not meet the new city codes enacted since we originally bought the pool. In hindsight, filling it in may have been a better idea, certainly much less expensive. At least we get to enjoy the pool again!
    This site has been very helpful. Great community here!
    18x40 gunite pool & spa (15k gal), remodeled 2016, Gemstone Pebble Finish, Pent. LED lights, Intelliflo VS pump, IC40 swcg, ScreenLogic2, FNSP60 filter, MasterTemp 400k heater, Silencer spa blower, TFT 100, Boric Acid, Kreepy Krauly suction cleaner, MAS DIY solar cover, GRI door alarms, Belgard Montecito coping and pavers, 36" fire pit, 2 Weber Smoky Mountain smokers, 32" Lion Gas Grill & Side Burner, Cinder block BBQ island
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hello from So. California - Pool Remodel
    Good luck with the remodel! We expect pictures before, during and after!
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    May 2016
    Laguna Niguel/CA
    3
    Will do!
    Casey's Avatar
    SW PA
    10,457
    Welcome! That's going to look nice!
