Thread: Pool toys and games!
    Apr 2016
    Anderson, SC
    11
    After a long SLAM I now have a beautiful sparkling pool to play in. I have 2 girls ages 5 and 8. Both are very good swimmers after a year of learning last summer. This past weekend was the first time in this year and they were perfectly happy just swimming around. I know that won't last long and they will be "bored" before long. What are some of the best pool toys you all have come across? All I can find in the local sporting goods stores are noodles, cheap floats, and dive rings. Surely there is something better out there. I'm looking into basketball goals for myself so ideas on that would be appreciated as well. Thanks and happy swimming.
    Justin
    IG vinyl liner, 26,000 gallon, Heyward sand filter with 1.5 HP pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool toys and games!
    Noodles are great. Diving sticks are fun. If you go the basketball or volleyball route, don't go cheap. They won't work and you won't use them. "Go big or go home" on those items. Our kids like the pump water cannons like these or similar simple cylinder style:
    Circular tubes are fun for them to play on as well. I've had the best luck with longevity on tubes designed for sliding on the snow in winter or ones designed to be towed behind boats as the rubber is substantially thicker and reinforced.
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The top all time durable favorite, Swimways Toypedo
    And for not so durable this style of squishy balls in various sizes
