Thread: Flex PVC in SW PA recommendations?
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    So I have to replace a leaky underground return line. Due to the routing and ease of installation I have decided to go with Flex PVC. Can anyone recommend the best Brand (TigerFLEX, HYDROFLEX etc) or requirements for SW pennsylvania?
    Thanks everyone.
    IG 16x32 Grecian - Vinyl - Approx 18k gal - 1 HP Hayward Super Pump - Pentair Triton II TR-60 Sand Filter - Hayward ColorLogic Light - Hayward H250FD Heater
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Flex PVC in SW PA recommendations?
    I have not seen many people use flex except in hot tubs, maybe someone will be along that has
    chclark's Avatar
    Sep 2012
    Pittsburgh, PA
    51
    Thanks!!!! after some more thinking, I decided to go with black poly. It was installed with pool oringally and lasted 20+ years. To me that is a great product test.
    Apr 2013
    Sacramento, CA
    2,769
    I would call your local building inspector and see if you are allowed to use black poly pipe.
