Thread: Syncing Pentair 5g LEDs without automation
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Electrician wired my two 12v 5g LEDs together using one transformer.
    I do not have the Pentair automation but do have the Intermatic Multiwave with remote contoller. The LEDs are controlled by 1 circuit as a switch.
    Pool is still under construction so can't test yet.
    Will the 2 LEDS start off syncronized? If they get out of sync will they reset when power is switched off and back on?
    Thanks.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Dec 2014
    Riverside California
    482
    Re: Syncing Pentair 5g LEDs without automation
    Here is a link to the 5G manual - Pentair Intellibrite 5G
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Thanks. The manual above has some more information that will help me but is dated 08/21/09.
    The manual that I got with the LEDs is dated 04/2015
    The 2009 manual did not call them 5G.
    Dec 2014
    482
    Sorry about that, copied the wrong link. Here is the 5G version
    The lights will re-sync is you turn them off for a short time then turn them back on. Using a switch to control the lights is a real pain. If you do not have automation then you should consider the Intellibrite 5G controller
