Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Which shape? Mt.Pond or rectangle?
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    We are trying to decide which shape to get. We are debating between a 22x36 Mountain Pond or a 18x36 Rectangle. The PB said the Mt pond will be a bit smaller than the rectangle as far as gallons. We are torn and love them both. Price is basically the same either way. Anyone with this size? Which do you have? Which do you prefer? We will be using it mostly for lounging around and parties my husband might swim laps but the rest of us will use it for play. Picture are alway appreciated. Thanks.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Which shape? Mt.Pond or rectangle?
    If you go with the rectangle, you have a standard size so covers/solar covers will be easier to come by. I also suspect a rectangle pool would be easier to brush, not sure though. Lots of asymmetrical pools look really nice so there is that.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Central Valley CA
    1,109
    From a design stand point most would say that rectangles are more formal, free form is more causal. The landscaping usually tends to complement the shape of the pool. If you have a lot of right angles in the yard might want to go with rectangle if you have sweeping lines or natural form to your shrubs and plants that can complement a free form. If you want to do laps or get an auto cover go rectangle, I would start combing through google images and see what strikes your fancy.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Nectarologist's Avatar
    Apr 2015
    New York
    428
    I have a 16x32 rectangle. I highly recommend a bench in the deep end, that area will get a lot more use with it (see my roman shaped end in the pic). I have a friend with the free form shape. I love it but it would not have worked in my yard (would have left some dead space). I prefer the straight edges but it's just a preference, it doesn't impact your enjoyment of the pool.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    We went back and forth between roman and free form for MONTHS. I like that geometric pools are more modern and it does seems like everyone is doing free form lately. However, I went with a free form shape because we are also putting a slide in and it made more sense. Search Pinterest and try to imagine what would make you the most happy to walk outside and see. Also think about which would compliment the style of your house or shape of your yard. Both of your choices sound like perfect size pools to me!!
    18 x 38 gunite, 39-7 deep, 8 x 12 tanning ledge with 8 deep water, umbrella sleeve, 2 LED bubblers.
    2 Pentair LED lights, 16 long fiberglass hill slide and jump rock. Sand dune pavers/coping. TF-100. My build: Georgia Pool Build.... No Longer O/B :))
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    I have a rectangle and like it so therefore you should too!
    We were doing an autocover and wanted the cleanest possible installation of one.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    We have a free-form. I love the shape but as others have mentioned, anything other than rectangular usually means custom, which = $$$. Safety covers, solar covers needing cut, ease of brushing, how much the robot climbs, etc. Are all things we didn't really consider when choosing our pool. I wouldn't change my choice, just would have saved more money before taking the plunge!
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Thanks for the feedback everyone. I didn't think about the solar covers being more expensive, or how the cleaners would work..those are for sure some things to think about.
    May 2015
    Land O Lakes, FL
    527
    We have a rectangle with some greco/roman design features. It is more formal. Rectangle uses the space more efficiently for the pool. Freeform might enable better design for the deck and orientation to the house if those things apply.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    SGPlayer's Avatar
    Apr 2016
    Palmetto, Fl.
    33
    We chose a design that was called mountain lake.
    That was over 25 years ago. Teal green was the popular tile color then. And cool deck over concrete was the deck of choice.
    A lot of angles. No smooth sweeping curves.
    Sorry about the poor image. Its a picture of an old picture... Hot tub / spa at one end with the entrance steps, swim out at the deep end.
    We liked it so much that we gave it a facelift 25 years later so that we can enjoy it for another 25 years.
    The teal tile had to go, pieces were cracked. Some were missing. The original deck had cracked in a few places.
    We thought long and hard about changing a few things (everything) Like adding a sun deck, different entrance stairs and loosing the hot tub / spa.
    But all we changed in the original design was loosing the glass block under the spillway of the hot tub.
    The deck was redone with set & grouted travertine pavers in a French pattern.
    But now, instead of all that teal tile being the focal point of the pool we mellowed the look with travertine around the pool and hot tub that matches the deck.
    No matter what you choose, once its done, you'll love it.
    Dave
    I'm Dave, the dog is Charlotte... 18k gal, IG pebble, Pentair clean & clear 150 sq.ft. cartridge filter, Pentair Intelliflo variable speed pump, 400,000 BTU propane heater, Blue Essence salt cell, Hayward Blu concrete suction cleaner, Pentair Intellibrite pool & spa lights, Pentair PSL4 easytouch automation.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    I personally feel that a rectangle pool is classic, elegant and provides the most usable space.
    I often wonder how people with squirrly curvy pools ever do laps?? Not that I necessarily want to do laps, but I want the option there! Y'know??
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Yes, the swimming space a rectangle provides is hard to beat. Like you, I like the idea of swimming laps (but realistically I doubt I ever will.
    So...I like the swimming layout of a rectangle the best, but I like the way the Mountain pond looks the best. It's a toss up for me. I keep googling pictures and they both appeal to me equally. I've been driving myself (and my husband) crazy....Our build doesn't start until July so I guess we have plenty of time to dwell on it and decide. haha.
    IG Vinyl Mountain Pond 22x36/ Depth: 3'4"-6'6"/ About 19,000 Gallons/ Pentair/ Clean&Clear Plus420/ Intellichlor IC40/
    Easy Touch/ Intellabrite 5G LED Color-Changing Light/ DeckJetsII/ S.R.Smith slide
    Aug 2015
    SW Ohio
    124
    You would have to go straight down the middle (of ours anyway) but laps would be possible in our freeform ...
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    Post some pics of your house and yard and a layout of your yard space with rough measurements. Even a hand drawn sketch will work. Pools that are really well integrated into and "in tune" with their surroundings always look great. It's hard to tell which pool will be perfect for your yard without a little more info. You can use tinypic.com to upload pics for free without an account if needed.
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    We weren't sure where to put the pool equipment so we plan on pouring a slab of concrete next to our hot tub to extend our exsisting patio. We'll move the hot tub onto it and away from the double doors....the idea we have right now is that we'll place the pool equipment between the hot tub and the fence (not in front of the gate but between the wall and hot tub). Also, if you can see the blue flags in the yard---that is where we plan on placing the pool. It's measured for the rectangle for now. We will also need a retaining wall in the back of our yard. We like the idea of a curved retaining wall rather than a straight one. We also plan on using a mixture of concrete and pavers. Brushed concrete decking around the pool for the slide and sunbathing area this year and next year doing pavers in the other areas. Excuse my poor sketches! LOL. I'm not an artist and it is not to scale...just my ideas. Any suggestions are welcome and appreciated! Thanks!
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Quote Originally Posted by Kpag View Post
    I don't have measurements of my yard but I added pictures of my house style and yard w/sketches. Didn't know I could use tinypic! I've never used that site before! Very handy! Thank you!
    Snap96's Avatar
    Jun 2015
    Chicago, IL
    39
    We were in the same situation last year. We knew that an auto cover was a necessity for us so after going back and forth, we ended up going with a rectangle since it really gave us a more streamline look, which we wanted, with the auto cover. We have no regrets on the shape we went with.
    A little pano picture of our setup.
    Barrier Reef Whitsunday 35' IG Fiberglass...17,500 gallons...Hayward H250 Heater...Hayward Max-Flo XL 1.5hp Pump...Hayward 24" Pro Sand Filter...Hayward Aqua Plus SWG...Taylor K-2006 and K-1004 Test Kits...Built Spring 2015...Use village well as fill water
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    I don't have a specific recommendation for pool shape based on your yard shape. It seems it would accommodate either with ease from a design perspective. What you do around the pool regarding decking/landscaping will determine how well it all ties together.
    I do however have an idea that you may not have thought about. Our backyard is also a continuous slope downward, though where our pool is, the slope looks steeper. You could consider having the retaining wall above the pool instead of below it, not far away from where your deck/hot tub area ends. A few benefits of this are as follows:
    1. You get to see the beautiful retaining wall all the time from the pool area - creates nice ambience.
    2. Your pool seating area has a nice backdrop to it, where your chairs/lounges will feel like they aren't sitting out in the open.
    3. The lower side of your pool may be mostly at ground level so everything you play with in the pool, balls, etc. won't go over the retaining wall and have to be retrieved. They will stay closer at hand.
    4. Your decking on the lower side of the pool will not be installed on back-filled material, which has a tendency to settle over time.
    5. You will get massive amounts of extra seating free of charge.
    6. Your seating area will be that much lower and therefore, out of sight of the neighbors prying eyes. We like our privacy as you can tell from the side landscaping. When you are seated out on the deck near your proposed retaining wall, you will feel as if you are on a stage for all to see.
    7. The pool will feel more connected with the rest of your yard/play area behind.
    Here is view of ours from the downhill side as a visual for the possibility. Our pool was still 2-3' out of the ground on the lower side, with the ground continuing downward as well. Our landscaped area below the pool slopes down massivly to account for that. I don't think you will have that nearly as much. Our shape too, as above, was a nod to practicality because we wanted an autocover.
    Either way it will be beautiful, I just wanted to highlight a different option and the benefits of it.
    IMG_1129 by Snowman 10, on Flickr
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    [QUOTE=Snap96;1024554]We were in the same situation last year. We knew that an auto cover was a necessity for us so after going back and forth, we ended up going with a rectangle since it really gave us a more streamline look, which we wanted, with the auto cover. We have no regrets on the shape we went with.
    /QUOTE]
    Thanks for sharing! We don't plan on getting an auto cover but I love the clean lines of this. Looks great! I love your bar area too! How do you like your slide? Is that the typhoon?
  20. Back To Top    #20
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Quote Originally Posted by bmoreswim View Post
    Great tips! I never thought about putting the retaining wall on the side near the house. I like that setup much better. Thank you!
