Thread: Removing skimmer basket
    May 2016
    Weymouth MA
    2
    Hello All,
    I am new to pool ownership. I have a question on the basket within the skimmer filter. My electrician who wired the pool says he is concerned about placement of the skimmer filter because it is a 4 inch basket with only 3 inches of room before it hits the decking. Therefore you can not take the basket out.
    The pool installers are telling me you take the basket out from inside the pool not outside. Can you tell me which is correct or does it matter?
    Thank you.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Removing skimmer basket
    Might have to be more specific. Filling out your forum signature would help. Edit Signature
    Is it an inground pool? If so, the skimmer lid comes off and you pull the basket out from the pool deck (top), not out the mouth of the skimmer that goes into the pool.
    Isolated Spa - 345 Gallons
    May 2016
    Weymouth MA
    2
    It is an above ground pool. The skimmer filter is under the decking.
